hi all
i have a lpg 4y in my hilux and am about to pull it out and put in a 2jzge, how does the lpg work with the injection system? is there a kit i can buy to fit the 2jz?
lpg 2jz
Re: lpg 2jz
You need to shut the injectors down use an emulator like this http://www.trademe.co.nz/Trade-Me-Motor ... 839397.htm
I know nothing about japanese engine names so no idea if that will be right for your engine but it will give you an idea what to look for.
You will need the correct mixer for you engine you alos have to restrict air flow by around 30% which is normally done by the in the mixer.
Re: lpg 2jz
Hey mate I have an lpg 5m motor and all that has been done is the injectors plugged and an emulator fitted.
works great.
works great.
