lpg 2jz
Posted: Sun Oct 12, 2008 7:49 pm
by 4runner
hi all
i have a lpg 4y in my hilux and am about to pull it out and put in a 2jzge, how does the lpg work with the injection system? is there a kit i can buy to fit the 2jz?
Re: lpg 2jz
Posted: Sun Oct 12, 2008 9:46 pm
by 91Rangie
You need to shut the injectors down use an emulator like this
http://www.trademe.co.nz/Trade-Me-Motor ... 839397.htmI know nothing about japanese engine names so no idea if that will be right for your engine but it will give you an idea what to look for.
You will need the correct mixer for you engine you alos have to restrict air flow by around 30% which is normally done by the in the mixer.
Re: lpg 2jz
Posted: Tue Oct 28, 2008 9:47 pm
by stoneym
Hey mate I have an lpg 5m motor and all that has been done is the injectors plugged and an emulator fitted.
works great.
