transfer case bung
MATT4U
transfer case bung
Post by MATT4U »
so I notice a slight oil leak coming from the crusier the other day, jump under it and notice its coming from the transfer case filler bung. thats funny i thought to myself. Reach up to wipe the oil off and notice its loose. I undo it with my fingers look in th e hole and see that theres almost no thread. so the previous owner has over tightened it. GRRRRRRRRR
any thoughts in fixing it. my current line of thought it i mite have to get a bolt with a slightly larger size and tap it to fit.
Any other ideas.
Jafa
Re: transfer case bung
Post by Jafa »
Helicoil
021 273 9942
jafa@inspire.net.nz
H2OLOVA
Post by H2OLOVA »
What he said. You'd struggle to get a tap that big easily. Sure beats covering it in silicone or some other dodgey fix.
MATT4U
Post by MATT4U »
H2OLOVA wrote:What he said. You'd struggle to get a tap that big easily. Sure beats covering it in silicone or some other dodgey fix.
I would never do such a thing, lol
I had thought about helicoil, however i have been advisedthat helicoil requires more thread depth than the transfer case would provide.
MATT4U wrote:I had thought about helicoil, however i have been advisedthat helicoil requires more thread depth than the transfer case would provide.
I had one stuck in my motorcross bike drain plug 20 years ago when I was young and skinny and could still ride those things, it would have been a lot smaller diameter than your truck plug but it seemed to seat ok in the alloy housing and never gave me any trouble like the rest of the bike did :?
tallsam66
Post by tallsam66 »
you can buy oversize bungs & also get special taps for them...i had to use one a 289ford sump once......no idea if they are available for japanese stuff though.
aroma
Post by aroma »
instead of a bolt get a bung the same size or larger we get them from taylors 3/4 inch bsp is what is in the navara(i think)
we might have a large tap at work i could "borrow" for a night if you wanted to give me the size
Chopper01
Rock God
Post by Chopper01 »
the helicoil will be fine just make sure you take it to bits before you do it so you do not get metal filings in the case
Pedro
Post by Pedro »
Chopper01 wrote:the helicoil will be fine just make sure you take it to bits before you do it so you do not get metal filings in the case
grease the tap, will catch 90% of swarf, then rinse the inside of the case with a degreaser, either from the filler and thru the hole with a spray can of degreaser,
Return to “Tool Shed”
