Interchangable Doors??????
does anyone know off hand if doors off a 3 door ln130 surf fit a 5 door?
Re: Interchangable Doors??????
no they dont the doors of a 3 door are the same as a single cab 2 or 4 wd , & the front doors of 5 door surf will fit on a ln 106 double cab but the rear doors are different for both surf & hilux .
lexlux wrote:no they dont the doors of a 3 door are the same as a single cab 2 or 4 wd , & the front doors of 5 door surf will fit on a ln 106 double cab but the rear doors are different for both surf & hilux .
so i stand corrected...
toymota thats stock standard.
Bugger, that foils that plan!
ive just been through all that i bought a cheap d cab but it had rust in the front 2 doors & it was cheaper to replace them with surf doors .
Yea i came across this also with my single cab. Single cab doors and 3 door surf doors are around 4inches longer from memory which is a bugger because a second hand singlecab door is way dearer to buy secondhand than a doublecab or 5 door surf door.
