4d56-t Rev limit 4grand?
wildplumdx
Post by wildplumdx »
just wondering what everyone else 2.5 mitsu diesel does coz i have a non turbo head on my turbo and was wondering if its restricting it? only getting 3,900 rpm at the rev limiter
red-devil
Re: 4d56-t Rev limit 4grand?
Post by red-devil »
i used to get 4100rpm when i was digging my way through mud.
pajeroboy
Post by pajeroboy »
cant really say as ive never hit the rev limiter,dont even no if mine has one/works.
33" muddies, 50mm body lift, ball joint flip, quick release front sway bar,40mm lifted rear dobi springs and new shocks,custom sill body armor,custom front bar.
SAM
wildplumdx
go find out lol plant ur foot and neutral and tell me :P
red-devil
Post by red-devil »
pajeroboy wrote:cant really say as ive never hit the rev limiter,dont even no if mine has one/works.
your motor should be lose enuff now. next time Pajeroboy when ur in the mud Feed the jandal to it.
HEHEHEHEHE
pajeroboy
Post by pajeroboy »
i no ive hit the red line on dash but i dont think the rev limiter kicked in.i find out one day prob just before it goes bang
although that would mean a new power house :D :twisted:
SAM
mfrsr
Post by mfrsr »
wildplumdx wrote:just wondering what everyone else 2.5 mitsu diesel does coz i have a non turbo head on my turbo and was wondering if its restricting it? only getting 3,900 rpm at the rev limiter
shouldn't be - AFAIK a diesel will keep putting on the revs so long as there's fuel (of any sort - hence why pajeros run when upside down, till they go bang) going into it, and the rev limiting is done by the governor in the fuel pump.
If it's worrying you, why not get the system checked over? or when was the last time you changed the filter?
wildplumdx
ok this was weird it did tap out at 3,900 rpm on the clock but you could still hear the engine going well beyond that, anyway i recently hooked up a boost controller gauge egt gauge etc and now the rev counter is working fine ? very weird ? doesnt make sense i did replace a pipe from the turbo to the pump with a new one maybe it was leaking and not reading right ? no idea ?
Return to “Mitsubishi”
