Page 1 of 3
Rear Disk Brake conversion on cruiser
Posted: Wed Oct 29, 2008 9:30 pm
by fweddy
While I have the diff apart on my cruiser and as the axle seal has burst and christened my brake shoes I've decided to do this mod as it appears to be simple and effective. I'm working with a 1985 BJ74 MWB Cruiser with fully floating rear axle. I've been to have a look at Nibz set up and talked to H2O regarding it - thanks guys
I'll do a build thread on it here for anyone considering it and to draw from the experience of others.
So far I am working on a pair of calipers. Have secured a pair of Subaru Leone (1986) calipers but am just waiting to get my hands on them. These have the hand brake included so are a good option.
Also Nibz is going to get me a pair of the custom mounting brackets - he has a pattern made up.
Next main part I need is the rotors. Best to use the same as the front of the cruiser which is also the same as beam axle hilux I understand. If any one is wrecking either a cruiser or hilux and have rotors, let me know. Is there a particular model hilux? 80s through to 90s?
Any other info appreciated. Keen to see what others have done to connect the hand brake up.
Re: Rear Disk Brake conversion on cruiser
Posted: Wed Oct 29, 2008 11:07 pm
by MATT4U
the disks aren't expensive new, infact some wreckers want more for stuffed disks than the price of new ones
Posted: Thu Oct 30, 2008 9:13 am
by H2OLOVA
Posted: Thu Oct 30, 2008 11:53 am
by fweddy
It seems the IFS surf rotors have been used but need a bit more machining.
Also from what I have discovered the LN106 Hilux (beam) is the same part as cruiser. Lineside guy said he wandered out and got some cruiser ones when he ran out of hilux ones. Can any one confirm or deny? Jase, you indicate they are thinner?
Looked at new prices for rotors (listed incl Gst)
Lineside $106.88 ea
BNT Rangiora $78.75 ea
Toyota Rangiora $162 ea
Repco Rangiora $83 ea
Trade me $75 ea
Posted: Thu Oct 30, 2008 1:03 pm
by rokhound
Push BNT harder on price. Trade deal this month on ln130 surf is $35 +gst ech.
Posted: Thu Oct 30, 2008 1:56 pm
by fweddy
rokhound wrote:Push BNT harder on price. Trade deal this month on ln130 surf is $35 +gst ech.
Can you access trade prices? - well normally even 'trade' is expensive compared to what tradesmen buy at...
I do have a fellow at a Mazda agency who does trade for me so I might try him after I have confirmed best price elsewhere.
Posted: Thu Oct 30, 2008 4:55 pm
by H2OLOVA
Just tell them you got the mailer at work and want that price
Posted: Thu Oct 30, 2008 5:25 pm
by zookfest
ive got maxima brakes on my cruisa with handbrake and i couldnt be more happy with it the handbrake works awesome to they are single pot off a 92 maxima.steve at 4wd stuff did mine have replaced pads once in seven months ive had them in
Posted: Fri Oct 31, 2008 6:51 am
by mattscruiser
try import parts lichfield st ph 365 7544 0800657544 i got my 80 rear roters for $56 each made in china of course
Posted: Fri Oct 31, 2008 8:17 am
by fweddy
mattscruiser wrote:try import parts lichfield st ph 365 7544 0800657544 i got my 80 rear roters for $56 each made in china of course
Thanks - gave them a call - they come in at a shade over $100 ea
Posted: Fri Oct 31, 2008 12:38 pm
by mattscruiser
oh it was a couple of years ago sorry
Posted: Mon Nov 03, 2008 8:33 am
by fweddy
Any one else interested in doing this conversion?
I've got a spare pair of callipers (mate bought some for adding disk handbrake to this MU but they don't fit.) PM me if interested in these.
or...
If some one else wants to do this conversion you can follow the contacts I'm putting here or if you are particularly unmotivated - while I'm getting everything together I'm happy to make up a second set for some one else. I've had some one suggest it could all be done for under $400 and I'd say that's about right.
Posted: Fri Nov 14, 2008 9:49 am
by fweddy
This morning I ripped all the drum brakes off and have it ready for the disks to go on as soon as I get parts in hand. Noticed one of the brake shoes was down to the steel
Do I need to use the large seal with the flange on it? I figure it is to keep muck out of the drum assembly and hence won't be needed on the disk set up?
Also I'm after one of those philipshead screws that is used to lock the bearing tensioner (heads are visible in the axle housing once halfshaft is pulled out) One was eventually removed with a punch and is quite mutilated so need replacing. They have a std screw thread with a short shaft on the end to lock into the keyed flange. Other wise I might see what I can modify to do the job. Could also do with a keyed flange in better order than one of mine.
FYI - It seems another source of calipers for this mod is maxima series j 30 maxima rear calipers. There is a guy selling a semi floating disk conversion on TM at present and is the second guy I've seen using maxima
http://www.trademe.co.nz/Browse/Listing.aspx?id=187513013
Posted: Mon Nov 17, 2008 1:14 pm
by fweddy
fweddy wrote:...
Lineside $106.88 ea
Trade me $75 ea
Just ordered rotors from my contact at Mazda - $135 pair ($67.50ea incl) so that's the best price I've been able to source.
Also have my caliper mount brackets (thanks Niblik) and will trial fit it all up to see where its going to sit and what needs machining. Then take those parts in to get worked on while I'm away for a week so should be ready to assemble when I get back. Hope to have this and other work done by mid Dec.
Posted: Mon Nov 17, 2008 5:14 pm
by Bulletproof
I might be barking up the wrong tree because I dont know how the cruiser setup is with the semi floating axle.
With a hilux there is too much side movement when you fit discs and it requires shims to made to remove a lot of the side play otherwise you end up with a soft petal.
Just a thought in case they are the same.
Richard
Posted: Fri Dec 05, 2008 8:29 am
by fweddy
Working with full floating Richard - will see what we discover when I get it together! You never know what new saga is around the bend. I'm working partly by faith in the fact it has been done a number of times before and partly by a sense of adventure!
Got one of my hubs/discs completed being machined. The inner hole of the disc has to be taken out to fit over the hub and the outer rim of the hub needs to be taken down quite a bit to fit in the disc. As Tim mentions in Pete's thread this now becomes a custom part and not so interchangable with other factory parts.
It now fits together well
Just waiting on the calliper brackets being modified a little to suit then can start assembly. And will need to organise new connections for the brake and hand brake, any one who has done this - I would appreciate any tips as to how you have modified the front back movement of the Subaru hand brake arm to the crossways cable of the cruiser.
Posted: Fri Dec 05, 2008 5:19 pm
by Genie4x4
Make sure you put in a larger master cylinder, when i did mine I couldnt get enough pressure from the original, if you have lifted it have you adjusted lengthened the weight compensator for the rear brakes?
Mine was done with hilux rotors, leone calipers and once it had all the niggles out it did awesome handbrake slides on 33s, we considered falcon calipers but they don't like mud.
I also extended brake hoses and handbrake cable at the same time as I had drop shackles on the rear.
Those that dont want a challenge some of the 73/74 series with the 4.2s in them came out stock standard with rear discs and its only a swap over job.
Posted: Fri Dec 05, 2008 6:11 pm
by fweddy
Not lifted so that side of things should be ok
Have run into trouble with brackets not in a suitable position. The handbrake mech is right in line to foul when the the axle articulates and meets the bump stop...
Posted: Fri Dec 05, 2008 6:17 pm
by Genie4x4
my brakes were right at the top, i didnt fit them. handbrake cable was two into one with a metal bracket, have a look at a wreckers on cars for the parts.
Not sure but can you reverse and put calipers on opposite side of truck should put handbrake at rear of axle then
Posted: Fri Dec 05, 2008 7:29 pm
by fweddy
My father had just finished kitting out his new toy (hiace) this evening so I grabbed him and we went and crouched beside the cruiser for a while holding bits here and there and reckon we have come up with a way we can do it by shifting the callipers to the top-front and modding the hand brake linkage. Will run twin short cables.
Posted: Sun Dec 07, 2008 9:25 pm
by fweddy
Spent most of today on fitting my disk conversion. Took most of the morning to do the first side and a couple of hours for the other
I got all my parts machined while I've been away for a week or so and picked them up on Friday but was still busy modding them more with the grinders and files
Here are the brackets that have been machined to mount properly.
They needed a little modding and after being painted I fitted them
And finally by the end of the day had every thing lined up and fitting nicely - few hours between these photos.
Just need to link up my brake line and hand brake. Brake line should be pretty straight forward.
Have two options for hand brake.
Split hand brake cable into two under floor and tuck them up along floor and curve down behind and under diff to connect to the linkages in their current location. or
Modify the the linkages and run two shorter cables in a curve. But might end up close to muffler.
Who is a good person in Canty to help out with the hoses and cables?
Posted: Mon Dec 08, 2008 5:48 pm
by Heath
fweddy wrote: Here are the brackets that have been machined to mount properly.
The stepped bit goes where? Is it a bearing retainer or just so it sits on the axle tube better?
Posted: Mon Dec 08, 2008 8:08 pm
by fweddy
Heath wrote:The stepped bit goes where? Is it a bearing retainer or just so it sits on the axle tube better?
So it sits over the lip on the axle flange.
Posted: Mon Dec 08, 2008 8:16 pm
by fweddy
Have run into a problem and need some wisdom.
Today I got a couple of small brake hoses to connect my callipers to the existing brake lines - work perfect so now its all plumbed up and ready to bleed but...
I can't get a pedal!
I'm getting straight fluid coming out the bleeders on all four corners. The peddle has a little pressure and then hits a hard sport. When we bleed the front that hard spot gives way. When the hard spot is reached it locks the front up but am getting no response from the back at all. pedal right down no braking but also no peddle?
I thought the piston might be stuck but that can't be the problem as, first, I should still get pressure and, when I actuate the hand brake lever it locks up.
other thoughts are that I'm getting a leak some where but there is no evidence of a leak.
One thought that did come to me is that the callipers are mounted further around the disk than their original position. This means the bleeder is not at the highest point - is that likely to be an issue?
Am aiming to get this mobile this week so any assistance appreciated.
Posted: Mon Dec 08, 2008 8:27 pm
by Jezza
fweddy wrote:Who is a good person in Canty to help out with the hoses and cables?
Diggers brake and cable is a good place for custom brake lines and cables, they're in hornby on haswell junction rd
Posted: Mon Dec 08, 2008 8:30 pm
by Smurf
If bleed nipple is not at the highest point you will have air in your calipers. Looking at your photos it looks like you could swap calipers from left side to right and that would put nipples at the top, not sure how this would affect your hand brake set up though.
Or can you rotate your bracket back one bolt to set bleed nipple at the top?
Posted: Mon Dec 08, 2008 8:42 pm
by Kiwimidi
Smurf wrote:If bleed nipple is not at the highest point you will have air in your calipers. Looking at your photos it looks like you could swap calipers from left side to right and that would put nipples at the top, not sure how this would affect your hand brake set up though.
this is correct had the same problem once on a safari after rebuilding the front diff and refitting the brakes we couldn't get pedal. got the brake expert round and the first thing he noticed was that the bleed valves were at the bottom..... we had put the calipers on the wrong sides this changed it all worked fine.
Posted: Mon Dec 08, 2008 8:47 pm
by fweddy
Jezza wrote:Diggers brake and cable is a good place for custom brake lines and cables, they're in hornby on haswell junction rd
Thanks - Got my hoses from Safe R Brakes but they can't help with cables so might try Diggers.
Can't rotate back as that fouls the hand brake
Could try swapping side to side - not as ideal for the hand brake (hence why I chose this position) but might be worth a try)
Or is it possible to do some other fancy bleeding technique?? (pressure etc?)
Posted: Mon Dec 08, 2008 8:56 pm
by Kiwimidi
fweddy wrote:[
not sure if it would work but unbolt them and slide the caliper round till the nipple is up then bleed them and put them back. would be a bit of a hassel with the handbrake attached and might be a bit hard cracking the nipple. worth a try though
Posted: Mon Dec 08, 2008 8:59 pm
by Smurf
can you take the rotor and caliper off your diff without removing brake line? If so rotate so bleed nipple is at the top, with the rotor still fitted into the caliper then bleed and refit. A bit of a rangi idea but would get rid of your air bubble.
Bleed nipples must be at the top to remove air as the trapped air will always sit at the highest point inside the caliper
