Surf ball joint spacers
Posted: Thu Oct 27, 2005 3:23 pm
by buggerburger
Has anybody tried ball joint spacers on their surf .Seems to be quite a common mod in Aussie & USA. Suspension lift without crankin the torsion bars up to much therefore not as much harshness from changed torsion bar spring rate. Heres a link from the aussie Surf owners site.
http://www.toyotasurf.asn.au/techsite/c ... ension.htm . Are thinking of making some myself .Had thought steel maybee easier and would definately last better under stress over time.Of course the grade of Aluminium would be a factor if making them out of this .
Will the certifier be happy with these ?
All thoughts and disscussion most welcome.
Ken
Posted: Thu Oct 27, 2005 3:58 pm
by MATT4U
i would be interested in these
Posted: Thu Oct 27, 2005 7:08 pm
by buggerburger
No prob Matt will make an extra set. Hopefully we have the material at work .will suss out tomorrow and start them next week.
If the cert guy doesnt like them they can always come of I suppose.
Posted: Fri Oct 28, 2005 10:17 am
by SupraLux
snap!
I was just investigating that very lift for someone here as well. Give me a shout on 021 637 600 - might have a business proposition for you if you want to make several sets - make the main spacers from T6 ali if you can get it, and the others from steel and have them passivated zinc coated.
Steve
Posted: Fri Oct 28, 2005 1:04 pm
by buggerburger
Hi Steve,
Yes getting the right ali might be the hard one . May be able to get it through work for a good price . Steel is more readily available & I think we have some spare floating around that thickness. Dont mind making a few extra sets but have to squezze it all in between the rest of my work and watching out for the boss as well
. May make up a jig to do a few sets which may make it easier. Should be able to get everything Zinc coated through work as well.
Will give you a bell
Ken
Posted: Mon Nov 21, 2005 4:00 pm
by NFORCA
Are you still making these? any rough idea on the cost?
Posted: Mon Nov 21, 2005 5:30 pm
by buggerburger
Still making these but is slow going as very busy at work . Have to squeeze work on these in when I can . Haven`t thought about a cost as yet . Will work it out once they are made.
Ken
Posted: Wed Nov 23, 2005 8:45 am
by MATT4U
NFORCA wrote:Are you still making these? any rough idea on the cost?
I thought you would be going down with ya height rather than up Todd
Posted: Sat Jan 14, 2006 10:54 pm
by JTop
Hi Ken
have you a price on these yet, I would probably be interested in a few sets.
J Top
Posted: Tue Jan 17, 2006 4:09 pm
by JJ
Has anyone installed a set yet? Very interested to see how it went. Any problems with steering geometry etc? I see on the Aussie link that they also lowered the diff. Not sure how they did the front mount.
Posted: Sat Jan 21, 2006 9:13 pm
by SupraLux
I suspect they left the front mount and just let it pivot down... dodgy, but hey... its just IFS...
Steve
Posted: Fri Apr 14, 2006 9:11 pm
by Dazlinsky
Hi Ken.
I have been looking into these to!!
Have you made a set yet if so I would like a set!!!
Please keep us all posted!!
Posted: Sun Apr 16, 2006 11:39 pm
by Browndog
how thick not me but the spacers no probs making them buy and old joit and copier it
Posted: Mon Apr 17, 2006 7:11 am
by Dazlinsky
Only an inch thick!!!!
The spacer not you!!!
I have a old ball joint if you want to copy one!!
Ball joint spacers on Surf
Posted: Fri Apr 21, 2006 11:10 pm
by buggerburger
Hi Guys,
My appologies , haven`t visited the forum for awhile .
Have finally made a set of ball joint spacers but have yet to fit to the surf. Also intending to look at the diff lowering as per the aussie site .
I copied of a ball joint to make up a template as a drilling jig and to shape the spacers
Still intend to make some more sets when I get a chance
Posted: Sat Apr 22, 2006 12:06 am
by MATT4U
I wont need any now funnly enough, lol
Posted: Sat Apr 22, 2006 10:08 am
by buggerburger
Cheers Matt
The swap looks fantastic
Posted: Wed May 10, 2006 1:00 pm
by PAID
what was the final verdict with this type of lift? sounds like a cheap and easy way to get more room under the arches
