Water proofing
- southland_Feroza
- Driver/Navigator
Water proofing
Just been tryng to water proof my motor in my 1990 feroza. What is the best way to water proof my distrabuter??
Re: Water proofing
rubber glove and cable ties......works!
Re: Water proofing
what the zooky man said .....
also move the coil as high as you can go and wrap it in a glove too.
grab a can of Softseal and spray it around the rest of the electrics ... this stuff is what the telco's use for sealing telecoms cables from moisture before burying in the ground. Softseal repeals water like you wouldnt believe.
