SUZUKI SPECS/FAQ/TECH
FAQ on other sites:
http://www.pirate4x4.com/forum/showthread.php?t=113614
http://www.outerlimits4x4.com/ftopic48714.php
http://www.outerlimits4x4.com/ftopic48779.php
http://www.off-road.com/trucks4x4/Suzuk ... ryId=45934
FACTORY SUZUKI SPECIFICATIONS AND INFO (please someone give links with more details!!!)
http://en.wikipedia.org/wiki/Suzuki_LJ
http://en.wikipedia.org/wiki/Suzuki_SJ
http://en.wikipedia.org/wiki/Suzuki_Escudo
http://en.wikipedia.org/wiki/Suzuki_G_engine
MOST POPULAR/USEFUL SITES FOR SUZUKIS
*will add when people suggest links*
BUILD UPS
ENGINE INFO
*will add more when people suggest links* (please someone give some more detailed specs on the different engines!!!)
DRIVETRAIN INFO
Suzuki gear ratios and handy calculator
http://www.xtremespyder.co.uk/technical ... ratios.htm
SUSPENSION INFO
STEERING INFO
RIM AND TYRE INFO
ELECTRICAL INFO
BODY INFO
BARWORK INFO
*will add when people suggest links* (pics, pics, pics, people!)
GENERAL/MISCELLANEOUS SUZUKI INFO AND MODS
I have created this post because I am new to zooks and have had quite a battle trying to find the info I am after, if we all chip in and help each other out here it will benefit us all, and people won't have to answer the same old questions over and over. So if you have any info you would like to add please post it up and I will add it to the original post. Hopefully if we get enough info together mike will add it to the tech library. How do I make this a sticky in the suzuki section?
gomulletgo
Re: SUZUKI SPECS/FAQ/TECH
http://www.suzukiinfo.com
http://www.izook.com
http://bbs.zuwharrie.com/content
http://www.twistedandes.com/foro
http://www.auszookers.com/index.php?name=Forums
http://zukikrawlers.com
http://www.azrockcrawler.com
Rock Lobster
http://www.mallo.nl/english/4.16.htm
http://ironbark.bendigo.latrobe.edu.au/~jeff/xfer2.htm
Rock Lobster
LR110 ..... LJ50 project
