Fitting airhorns to L200
Posted: Sat Nov 15, 2008 10:44 am
by mudbugga
Hey guys. I'm trying to hook up some airhorns on my truck.
I was trying to use a relay, but the horn is earthed up in the steering wheel pad. (There is an earth and a constant 12v at the horn). I gave up trying to fit the relay and have just used the terminals to the horn and put them straight onto the airhorn compressor. Hopefully the currant draw for the compressor won't be too much for the std system.
What is the best way of connecting airhorns up using a relay?
Re: Fitting airhorns to L200
Posted: Sat Nov 15, 2008 11:05 am
by Sadam_Husain
Can be done with a relay, when I did my engine swap a couple of years ago the air horns stopped working and I had to rewire the relay, cant remember what I did other than trace out the old horn feed and re-wire it onto the relay :?:
Posted: Sat Nov 15, 2008 12:43 pm
by skid
have transferred air horns thru about 5 or 6 different cars now and everytime, all I've done is use the existing horn wiring and bolt the compressor close to the original horn location so that everything reaches.
have never ever had a earth problem or the need for a relay so far
Posted: Sat Nov 15, 2008 1:07 pm
by kiwipete
mudbugga wrote:Hey guys. I'm trying to hook up some airhorns on my truck.
Substitute the headlight wiring etc for the horn wiring.
Posted: Sat Nov 15, 2008 1:29 pm
by 91Rangie
why not just use the earth to activate the relay?
Instead of earthing the relay to body use the orginal horn switch to earth and activate the relay.
Posted: Sat Nov 15, 2008 2:07 pm
by mudbugga
Cheers Guys
91Rangie, I'll give your idea a shot.
Posted: Sat Nov 15, 2008 2:33 pm
by sig
91Rangie wrote:why not just use the earth to activate the relay?
what he said is how mine works and works good
