GEW10000LB Runva Winch
kiwipete
Post by kiwipete »
Hi all, I now, after much emailing and googling, have secured a full 20 page manual for the above mentioned winch; from china! No such luck or replies from the NZ agent. :(
This has all part numbers and exploded views etc of the disassembled unit.
If anyone wants a copy I have it in PDF format and can email it to you.
Just send me and email if you want a copy. :wink:
Ph 0212078472
Cloggy_NZ
Texas Chainsaw
Re: GEW10000LB Runva Winch
Post by Cloggy_NZ »
Email sent.
Thanks
Smurf
Post by Smurf »
thanks for the manual Pete
kiwipete
Post by kiwipete »
No probs, just wish the NZ agent was as helpful.
I am going to strip my one after Xmas cos it has water in the gearing side.
Does anyone know what grease I should use to re-grease it?
BTW i haven't read the manual yet. :oops:
Ph 0212078472
marine hi preesure grease
cruzerboy
Post by cruzerboy »
Cheers pete
northland_pajero
Post by northland_pajero »
Thank you
kiwipete
Post by kiwipete »
Cheers guys. :wink:
Have any of you had any dealings with the NZ agent for these winches. I personally have had no luck at all with emailing him, but I must say the responses I have had from Runva in China are fantastic. (although sometimes their spelling leaves a little to be desired, "I am sorry because it's difficult to spell. Do you know the bisulfide with cuprum.") :shock: :?
They are even going to send me some free grease! not that I need it. :wink:
I will be pulling mine apart in Jan/Feb sometime to re grease it and see if there is any way to stop water ingress.
Ph 0212078472
northland_pajero
I bought my winch of Michael in Auckand (via trademe) under warranty he replaced the solinoid box (twice but it was only broken then first time, the second time the motor had packed up) and the motor once, no questions asked, he was good to deal with.
DieselBoy
Post by DieselBoy »
Micheal has been good to deal with, he has sent me two motors and a gearbox, and today he sent me a whole new winch (EWX12000 to replace my GEW10000).
You need to email him first thing on a monday morning, and you usually get a reply from him by wednesday, i don't think selling Runva winches is his day job, its something he does on the side??
As for water ingress, i havn't found a way to stop it. Just strip it down every couple of months, or after a deep river crossing/trip. I just coat everything in water proof grease, make sure you don't get any on the brake system though!!!!
Make the winch easy to take off when you are working out how to mount it.
kiwipete
Post by kiwipete »
Maybe its just me, but none of my emails over the past 6 odd months have been answered. :?
Ph 0212078472
Heath
Post by Heath »
kiwipete wrote:Hi all, I now, after much emailing and googling, have secured a full 20 page manual for the above mentioned winch; from china! No such luck or replies from the NZ agent. :(
Have you still got the PDF file, I have one of these on the front of my prado.
Dont like the clutch setup though (stupid sliding thingee and not a twistee handle thingee. :mrgreen:
kiwipete
Post by kiwipete »
Mines as stiff as a board to rotate so I think its time to pull it apart and re grease it. Need to build my workbench first tho.
Ph 0212078472
Heath
Post by Heath »
Never used mine, its there for show. :mrgreen:
Will get round to having a play with it eventually, but the clucth set up is a pain in the ass and I cant get a good purchase on it due to my bar design. :evil: .
kiwipete
Post by kiwipete »
Heath wrote:Never used mine, its there for show. :mrgreen:
It is easy enough to rotate to get a better position too, just unscrew all those screws at the side and rotate to the desired position then replace the screws. :wink:
Ph 0212078472
flyingbrick
Post by flyingbrick »
kiwipete wrote:Mines as stiff as a board
.................................you and me both pal, you and me both.
:lol:
nuts
Location: somewhere arround westcoast offroading usually
Post by nuts »
:lol:
Just a tad too much info there me thinks. :? :shock:
Return to “Tool Shed”
