Adjustable Oxygen Sensor Simulator
Posted: Mon Nov 17, 2008 6:54 pm
by krokkie
Has anybody had any experience with this product sold on Trademe?
It replaces the O2 sensor when the catalytic converter has been removed.
This is my problem - my converter is falling apart and will need replacing soon.
What are the replacement cost for a catalytic converter and o2 sensor?
Are there any other options out there?
Re: Adjustable Oxygen Sensor Simulator
Posted: Mon Nov 17, 2008 10:09 pm
by WACKO
id replace it with straight pipe.... not sure how legal it is these days, but i would think it was fine, as all those rice racers (well some of them) still get WOFs and you can almost garuntee they arnt paying for 3" high flow cats..
Sam
Posted: Mon Nov 17, 2008 10:20 pm
by Andrew1706
You can gut the cat converter and fill the void with a straight thru pipe, that way from the outside it still looks like you have a factory cat fitted.
But then you might get complaint from greenies :evil:
Posted: Tue Nov 18, 2008 5:27 am
by krokkie
Thanks guys, my idea is to get rid of the cat, but the sensor will go haywire without the cat, and the engine light will stay on. Which is what I don't want. Plus of course without the sensor, the ECU will enrich the mixture, and the fuel economy will go belly up.
Any suggestions?
That is why I am looking at this Adjustable Oxygen Sensor simulator on Trademe
Posted: Tue Nov 18, 2008 5:48 am
by adogg
krokkie wrote:Thanks guys, my idea is to get rid of the cat, but the sensor will go haywire without the cat, and the engine light will stay on. Which is what I don't want. Plus of course without the sensor, the ECU will enrich the mixture, and the fuel economy will go belly up.
Any suggestions?
are you sure the sensor your looking at is the oxygen sensor? a lot of that jap stuff has a small sensor actually in the rear of the cat which brings up a light on the dash to say the cats overheated,oxygen sensors are generally before the cat mate and usually close to the engine.
Posted: Tue Nov 18, 2008 7:16 am
by krokkie
This sensor is on the cat, in the middle.
I will have a look in the front towards the engine if I can see anything else.
If the oxygen sensor is not on the cat, can I just replace it. I read somewhere that if you remove the cat it screws up the sensor readings.
How safe is just replacing it with a resistor?
Posted: Tue Nov 18, 2008 5:28 pm
by adogg
more than likely what you looking at is what i described above,the oxy sensor will be closer to the engine,is it a v6 one?they usually have one sensor per bank or one just after where the two exhaust pipes merge into one usually have 3-4 wires on them,if the cat is downstream from this then you are safe to remove it,i wouldnt try and dodgy it as the engine ecu uses this to determine fuel mixture
Posted: Tue Nov 18, 2008 6:51 pm
by TJ
Any suggestions?
Actually in a system that can tell cat efficiency or effectiveness, there are two O2 sensors (one before the cat and the second just after). The difference between the two readings tells the computer how well the cat is performing. For such applications, a missing cat will cause an alarm code. If you have only one sensor and it is before the cat (towards the engine) and you remove the cat, the engine computer has no way of knowing that the cat is missing now!!! I can detect its absence since there are no sensors.
So check how many sensors do you have total and where. Besides, a new hiflow cat is not that expensive. I have had mine replaced for around $280 fitted. O2 sensor was about $160 fitted.
Posted: Wed Nov 19, 2008 5:08 am
by krokkie
Thanks for all the help, I will have a look for the position of the o2 sensor/s.
Posted: Wed Nov 19, 2008 5:50 am
by NJV6
Is it on a Pajero?
If so, replacing the cat with a straight pipe and not having the sensor pluged in will not cause a check engine reading. I have done this.
There is a seperate oxygen sensor.
The sensor that is now not inside the cat is just still plugged in but tied up out of the way, and my fuel economy is pretty good.
Posted: Wed Nov 19, 2008 10:58 am
by krokkie
That is good news.
Will it pass WOF with a straight through pipe?
Posted: Wed Nov 19, 2008 11:00 am
by krokkie
May I ask what your fuel economy is?
I'm getting around 5km/litre.
Posted: Wed Nov 19, 2008 1:17 pm
by NJV6
Mine is WOF'd!
Open road - 11 to 12l/100km
Around town - 12 to 14l/100km
4WD - 14 to 25l/100km (25 only in extreme cases!)
Average over thousands of km (incl 4WD as that is all it is used for) Between 13 & 15l/100km.
3.5 litre SWB Manual.
Posted: Wed Nov 19, 2008 3:25 pm
by krokkie
Cheers for that.
I had a look, and it seems the oxygen sensor is where the two banks join, and it appears to be a 4 wire, but I couldn't really see that well.
Posted: Wed Nov 19, 2008 7:01 pm
by NJV6
Yes, 4 wire
