surf proportioning valve
Posted: Wed Nov 19, 2008 5:19 am
by truck-fixer
Hi all, one of the guys at work was told by Mr WOF to adjust his proportioning valve on the brakes in his 1992 LN130 Hilux Surf. I havn't had a chance to look at it yet, but if I could get a heads up on where it is located on the vehicle and how to adjust it properly that would be great. Thanks all.
Matt.
Re: surf proportioning valve
Posted: Wed Nov 19, 2008 8:40 am
by tweake
has the surf been lifted ? if so the easiest way is to just add a block to compensate for the lift.
Posted: Wed Nov 19, 2008 7:06 pm
by truck-fixer
tweake wrote:has the surf been lifted ? if so the easiest way is to just add a block to compensate for the lift.
No, stock standard matey.
Matt.
Posted: Wed Nov 19, 2008 7:25 pm
by gimmemud
On the back of the rear diff head there's a bolt which has a line going to the proportioning valve which is on the chassis.
You should just be able to give the nuts a couple of turns and that should change it a bit.
stolen from bulletproofs thread.
Wouldn't have thought you would need to adjust this on stock standard suspension though.
Posted: Wed Nov 19, 2008 7:28 pm
by tallsam66
Did the WOF guy put your hilux on a breakmachine to tell there was a problem or did he just do it by feel ????
Posted: Wed Nov 19, 2008 8:35 pm
by tweake
with no lift, unless the valve arm has been hit or otherwise adjusted, you should not need to adjust it.
more than likly the rear brakes are out of adjustment or worn.
Posted: Wed Nov 19, 2008 9:44 pm
by truck-fixer
gimmemud wrote:On the back of the rear diff head there's a bolt which has a line going to the proportioning valve which is on the chassis.
Awesome thanks mate.
tallsam66 wrote:Did the WOF guy put your hilux on a breakmachine to tell there was a problem or did he just do it by feel ????
Don't know my friend, I just saw the fella's WOF sheet.
tweake wrote:with no lift, unless the valve arm has been hit or otherwise adjusted, you should not need to adjust it.
Will have a look see tomorrow to find out what's going on with the poor girl, may just be another case of Mr WOF talking fancing words whilst not knowing what he is talking about
. Will let you all know when I get to the bottom of it.
Thanks for all your help people. Appreciated.
Matt.
