http://www.trademe.co.nz/Browse/Listing.aspx?id=188538610
and
http://www.trademe.co.nz/Browse/Listing.aspx?id=188203716
i dont really want to spend more than $2,000, and I'll need it as a daily driver so it has to be reliable
what are the main differences between a hilux and a surf?
the hilux has a suspected leaking head gasket.... are these easy to fix and cheap?
the surf has a leak in the power steering.... are these easy to fix and cheap?
the surf hasnt got a cert for the wheels or the body lift, are they hard to get? how much do they cost?
and its got a fuel injected engine too, i thought these came out later? is the efi engine better than the carby one?
im new to 4wd'ing so it'll need to be good for a beginner to learn in and easy to drive.
the surf already has some big tyres and a 2" body lift, but the hilux has dual fuel (lpg/petrol) so will be cheap to run
theyre both 2 litre petrol engines. are these alright for going offroad? i guess i can upgrade them later if i have to?
what are your thoughts?
dave
