Transfer Bearings
Transfer Bearings
Does anyone have a list of bearing and seal number for an SJ410 transfer case?
Re: Transfer Bearings
What year 410?
84+ 410 have the same transfer bearings as a 413. I can dig out my part numbers for you . cost me about $150 for all the main roller bearings and 3 seals.
LR110 ..... LJ50 project
That would be awesome if you could.
It's an '84 (4wd switch model) so your number are most likely the right ones
Can't find my docket but ive the part numbers off the boxes. The bearings i have are NSK brand from Japan.
http://www.nsk.com
I got them from Presion Bearings in New Lynn Auckland. About $150
They are the Local NSK dealer, should be one in Whangarai.
# 6306NR*C3 703 (Large roller bearing with Circlip) x1
# 62/28C3 801 (Main Roller bearings) x 3
# 63/22C3 807 (Input shalf end roller bearing) x 1
# TC12539 (Smaller Seal, Front output i think? ) x1
# TC12545 (Larger Seal) x2
http://www.nsk.com
If you have no joy with then, let me know and I'll find the Suzuki part numbers for you.
