Legal Fiddle Brakes for the Rover
Posted: Mon Nov 07, 2005 2:08 pm
by De-Ranged
I did this some time ago, and never posted anything about it :roll: now as I'm selling it I've had to post the pix to show what I've done so I thought I'd throw it up for everyone esle to see
"Road Legal Fiddle Brakes"
By putting a whole new brake calipure onto the axle and it not effecting the current braking system you "by-pass" all the cert problems 8) and would you believe all it is for a cert is a low level :lol: all they need to do to pass it, is a visual of the welds
And all you use to run them is a hyd clutch master cylinder, a nice common one would be a hilux one
:lol: hope this sparks some ideas
Cheers Reece
Posted: Tue Nov 08, 2005 11:38 am
by mercutio
i've been thinking about doing something like this but use air to operate the brakes the theory of using is is that you only really use fiddles brakes to stop spinning wheels so you don't need as much control to operate them i.e. max pressure should stop them
Posted: Tue Nov 08, 2005 12:05 pm
by DieselBoy
But if you have good control over the pressure, they can be used as a traction aid.
In that situation, you don't want the wheel locked, just to even the load on the diff between the wheels so they both get drive,as it would in an even traction situation.
It would be simpler to set them up with the hydraulics anyway!!!
Posted: Tue Nov 08, 2005 3:28 pm
by eatenfuller
:D fiddle brakes are overkill on a bush trucks thats why i ripped mine off last weekend its just more crap to break (i only put them on to be a wanker to keep up with the jones's)
different storey on trials trucks i think there a must :D :D
;-p
Posted: Tue Nov 08, 2005 7:04 pm
by wopass
pffft.. brakes are for pussys..all they do is slow you down... :wink:
Posted: Tue Nov 08, 2005 7:39 pm
by DieselBoy
So are 36" competition tyres :wink:
Posted: Tue Nov 08, 2005 8:12 pm
by De-Ranged
:lol: you've never driven brittish have you .... as somebody who has and has perfected the 10 piont turn, anything that improves the steering circle is good!
Have a good look at the brake line garding 8) 1 step ahead of you on that one :wink: by the way still waiting for that info on independent syspension there EF
Cheers Reece
Posted: Wed Nov 09, 2005 7:07 am
by eatenfuller
:lol: :lol: british yuk did you say ERF yuk :oops:
sorry de-ranged forgot all about it/ BRIAN HOWAT(HOWAT ENGINEERING)O45671471.most 4wd nuts that havent heard of brian should be SHOT he used to make his own air lockers(which grant guy uses in the front of his truck) ,but now he makes hydralic ones (trials trucks only)from cromo axles to spools for street cars theres nothing brian cant do but like anything it comes with a price tag.but see how ya go de-ranged hes a nice guy and will be happy to help mate :D :D
Posted: Wed Nov 09, 2005 7:41 am
by De-Ranged
Thanks for that EF
I did have his number was going to give him a call for prices on the axles once I worked out what I was doing :oops: I hadn't thought it was Brain Howat that owned it :lol: he'll deffinitly be worth calling!!
Cheers Reece
Ps this might be happening a bit faster than I thought as I've possibly just done the engine in my test truck and I've got a lexus sitting doing nothing :twisted: if I'm going to cert that sort of swop I'll need to do the brakes so I might as well do the syspension as well :roll: :twisted: Damm this is shades of "Lemon"... the only thing I'm keeping is the cab!! :roll: :lol:
Posted: Wed Nov 09, 2005 1:49 pm
by eatenfuller
:D :D no worries happy to help and keep posting pics mate (i see nothing past hiluxs) :lol: :lol: :lol:
Posted: Tue Jul 25, 2006 9:01 pm
by turoa
Could ya get the pics up again? and some of your levers.
Posted: Tue Jul 25, 2006 10:27 pm
by Jerry
Landrovers have brakes???????
Posted: Tue Jul 25, 2006 10:37 pm
by JTop
Hi Turoa
are you running endless air? I am going to run twin VH44's modified so the atmosphere chamber will become an air chamber so I can air activate them individually, 1 for each rear wheel, they should take 60psi ok and will enable disc fiddles to work
J Top
PS Andy still says I only need 1 caliper to do this and my service brakes
Posted: Wed Jul 26, 2006 10:52 pm
by turoa
JTop wrote:Hi Turoa
J Top
Yea, im convertin an old air con compressor to an air compressor. The VH44 idea sounds interesting. Does it just have a resivoir at one end of the line? And do you have a good supply of VH44's? Im still looking for some :lol:
Posted: Wed Jul 26, 2006 10:56 pm
by JTop
It does not need a reservoir because it is plumbed into the service brakes
as approved by Andy
J Top
Posted: Thu Jul 27, 2006 4:53 pm
by turoa
hmm, if the galant calipers have enough braking, I might try this.
