It only does it after i have been thru watery mud, and it always comes right in a few days by itself. it will drive fine on firm ground, or boggy mud (if you know what i mean) but the clutch will always get stuck after watery mud.
i have read thru the old topics about this problem, i have tried putting a hose in the bellhousing thru the clutch fork hole, and pumping the clutch while doing this. But that didnt seem to work, altho i was surprised that the water running thru and coming out the bottom of the bell housing was clear.
any other ideas what i can try? ... i am not particularly mechanical (if you couldnt tell
