O.M.E GEAR
J_Dub
O.M.E GEAR
Post by J_Dub »
Whos the best people to deal with to purchase O.M.E gear?
Preferably in Auckland and what sorta price will i be looking at for a set a leafs for all 4 corners
monaro427
Re: O.M.E GEAR
Post by monaro427 »
should check out jafa's stuff from trail gear, his prices aren't to bad :D
J_Dub
Re: O.M.E GEAR
Post by J_Dub »
how do i get hold of him? P.M him or has he got a website???
turoa
Pyro Junior
Re: O.M.E GEAR
Post by turoa »
Re: O.M.E GEAR
monaro427
Re: O.M.E GEAR
Post by monaro427 »
you could pm him as well and this is the website.
http://www.snr4x4.co.nz/
turoa
Pyro Junior
Re: O.M.E GEAR
Post by turoa »
is there an echo in here?
J_Dub
Re: O.M.E GEAR
Post by J_Dub »
turoa wrote:is there an echo in here?
haha, i was thinkng the same, big echoe, cheers guys, just had a look and ive emailed him
Re: O.M.E GEAR
dull day should be at thompsons with the m4wdc but stuck at home :?
J_Dub
Re: O.M.E GEAR
Post by J_Dub »
coxsy wrote:dull day should be at thompsons with the m4wdc but stuck at home :?
i second that, bored shitless, little seedy too tho, had planned to go on that Thompsons run with the old man but hes tied up today, its there last run too i think b4 xmas
Re: O.M.E GEAR
well we can go next sunday
J_Dub
Re: O.M.E GEAR
Post by J_Dub »
we taking the 2 trucks to woodhill next weekend, probly dry as, but im keen just to go for a nosey
darinz
Re: O.M.E GEAR
Post by darinz »
Auckland 4x4 in Papakura is the closest OME agent to you. arbinfo@ihug.co.nz is their email or www.autoelec.co.nz is their website.
albundy
Rolly Polly
Re: O.M.E GEAR
Post by albundy »
OME gear is made for desert touring in the Aussie outback, not the stuff we deal with in NZ. You will be bitterly dissappointed with it if you fit it. Springs sag, shocks stuff out.
Al
Robo
Re: O.M.E GEAR
Post by Robo »
albundy wrote:OME gear is made for desert touring in the Aussie outback, not the stuff we deal with in NZ. You will be bitterly dissappointed with it if you fit it. Springs sag, shocks stuff out.
Al
My OME sagged 25mm within 2 months (really not happy and heaps of other are saying the same thing) I've had to put 2 xtra springs in to bring it back up
Windsock
Re: O.M.E GEAR
Post by Windsock »
Al
Must be a leaf spring thing cause the coils & shocks I put in back in June on the front of my LandRover 110 haven't sagged one bit and it is now carrying a 9000lb ramsey winch on there now installed since then. Shocks are still as good as the day they were in also. I've also done OME coils and shocks on the rear and its is a fine combination. I drive a lot of river bed work over boulders etc with firewood and not a problem with them.
nstacey
Re: O.M.E GEAR
Post by nstacey »
O M E leaves are now made in Thailand. That's the main reason I went with EFS on my Hilux, still Aussie made
85 Hilux single cab
02 Grand Vitara
TJ
Re: O.M.E GEAR
Post by TJ »
Al
I wonder why they have always done so well in the US then? Perhaps you had a bad batch?
I am running OME shocks and springs and no problems at all so far. Whatever sagging is there is because of the weight and age of the suspension, still work extremely well in terms of flexing and road performance (equally).
J_Dub
Re: O.M.E GEAR
Post by J_Dub »
good to get everyones feedback, still unsure of what to do with my suspension, definately dont wana folk out the coin for something thats not going to last... then some say o.m.e is the go, some say that are shite... contimplateing doing some digging around at wreckers to find another spring off another different vehicle all together that will bolt straight in and give a bita lift, ive seen someone used mazda b2000 springs, maybe do a bita mix n matching, then fit rears up front
darinz
Re: O.M.E GEAR
Post by darinz »
Al
Well I've been using OME suspension in comptetions since 2005. FOR THE SAME MONEY they are almost impossible to beat. The only other brand that is comparable is EFS. There are much better shocks out there but you will pay a lot more for them.
As for being dissapointed with them, it will depend what you are comparing to. Bilstein, Koni, Fox etc will perform better and last longer so compared to them you will be dissapointed, but they all cost at least twice the price.
And the guys that run EFS carry spares for when they stuff the seals but the guys using OME don't need to.
This is my experience from racing against guys using this gear in real NZ conditions.
But if you want the best their is always Rancho. After all any made in the US must be the best quality, the success of their economy proves that!!!!!!!!!!!!!!! :lol:
gary_in_nz
Re: O.M.E GEAR
Post by gary_in_nz »
i run Maxitrac (aussie) springs, which havent sagged in a year and a half, and OME shocks, good handling on road and good off the tarmac aswell
UBZ
Re: O.M.E GEAR
Post by UBZ »
IM running O.M.E coils and shock in my Surf.
Very happy with the performance. 40k on them with no noticeable change in performance. Still drives better than my mates Surf on new Rancho's.
Coils have sagged a little but I went with the softer spring rate to get better flex.
My mate is running O.M.E leafs and shocks on his SJ410.
Truck had been sitting for about 3 years and we were quite depressed at how much the leafs had sagged.
However after one trip out the leafs had re-set them selves and the truck is still still sitting up were it should.
The shocks however were well to short for the application. As soon as the sways bars came out we maxed out there travel.
Its my understanding the O.M.E gear is setup as packages ,normally to accommodate only a 2 inch lift and is designed around driving comfort and not off road ability / flex / etc.
zebedee99
Re: O.M.E GEAR
Post by zebedee99 »
i had some old retensioned springs on my FJ40 which gave it a nice 3" lift - until i went offroad over christmas and the front ones went completely flat - and stuffed the shocks. guy at the garage said he'd never see any go so flat without broken leaves!! have put in OME dakar springs on the front and OME shocks all round. road handling is much improved. off road and how they hold up is yet to see. that said, i lived in africa for a while, and OME were the dogs testicles. mostly light off road / bush tracks in a discovery, but they improved handling no end. my 2c. talk to marcel at motortech4x4 in glenfield - they did a good job for me.
Dak
Re: O.M.E GEAR
Post by Dak »
OME for me to, been running it for about 5 years and havn't had a single problem, can't be beat for the price.
J_Dub
Re: O.M.E GEAR
Post by J_Dub »
anybody know the thickness of the o.m.e leafs?
Return to “Tool Shed”
