POWER STEERING ISSUES
brakes-shocks-lockers-etc
WACKO
Pyro
Post by WACKO »
vehicle is my pajero. ive done a SAS to it and used a prado power steering box. ive also installed a evo4 power steer fluid cooler as i had to remove the cooler tube that was previously in it. cooler is on the low pressure pipe.
now the problem is this... the steering violently goes from lock to lock by its self. so violetly when trying to stop it, it dam near bent my fingers off. goes from one side then snaps back the other way. also after only not even a minute the pump is almost too hot to touch and the lines are very warm to the feel, but this may be due to me slowing the spinning of the steering wheel to see if it is just doing it while circulating the oil or somtheing.
it also seems to be leaking slightly from the hight pressure line.
im guessing its not normal, so have i hooked something up backwards/wrong? does it just need a blead from somewhere? what am i missing?
cheers, Sam
wopass
Re: POWER STEERING ISSUES
Post by wopass »
does it go lock to lock when your stationary by itself ? thats some wierd shit right there!!!
if its when your driving i would sugest you have your steering geometry a bit out and need to set your castor better, you probably have your diff rotated too far forward... but im only guessing
turoa
Pyro Junior
Post by turoa »
you got the high and low pressure lines around the wrong way? sounds like its trying to push fluid in the out way?
Jafa
Post by Jafa »
turoa wrote:you got the high and low pressure lines around the wrong way? sounds like its trying to push fluid in the out way?
x2
021 273 9942
jafa@inspire.net.nz
WACKO
Pyro
Post by WACKO »
thats what the hydraulics shop reckons too. guna swap em round tonight, heres hoping the fittings are the same size.
wopass.. yip.. while it was stationary... freaked me right out!
WACKO
Pyro
Post by WACKO »
the lines were hooked up back to front, got them swaped today, but now they are leaking... BIG TIME.
so out comes the entire p/s box and the whole lot is going to the place tomorro to get it sorted.
tomorro is looking expensive... gota get brake lines and things aswell... :(
niblik
Post by niblik »
been there guy... its not a cheap exercise... :cry: still...... you'll be glad and oober stoked when its all done... :wink:
WACKO
Pyro
Post by WACKO »
with the way the paj is set up its only cost me bout $20 a time, so not too expensive. and today they redid the leaking fittings for free. and all fixed!!!! no leaks, and no crazy steering wheel!
