Madterrano goes solid
Posted: Mon Dec 15, 2008 9:26 pm
After lots of questions, talk and planing MT is finally doing a sas on the Mu.... and a wee playing round with the rear to level it out
Basic deal is as cheap as possible, definitly helps when you know the parts manager at Toyota
So we are looking at hilux axle which he got for free (discovered later there were a few missing bits and it was bent
) mounted on a set of Hilux IFS rears and extended shackles... change the steering over to X over steering running an IFS hilux box, out back SOA and just extend the shackles to level it, MT is gona try and do as much as possible that said
I think he's sick of the grinder....
As it rolled in the shop friday night
And yes MT is the one about to do the haka
The fun begin's toy up on jack stands stipped all the IFS out , the drivers side A arm had to be cut out
bolt was rusted to the mounting bush to the piont the truck was moving on the stands from the hammer used to try and push it out.... cut the bastard off with the nine inch
Lots and lots of this
It ends up like this
taking a break from grinding
I helped him setup the axle.... noticed the axles didn't want to go in... oh joy pull out the straight edge and have a measure up found both sides were bent
alot of pissing round and its straight again... funny thing they never bend where the americans put there bracing
its alway either side of the pumpkin going either forward or back
Anyway a traded 4.56 slippery in there and the axles drop in this time, then start sorting the swivil housing kit... this is where we noticed the solid axle which he'd bought in parts was missing a few parts
only 3 taper washers and nuts
managed to scrap up another 8 from bits in the shop so we set up the arms, while he was grinding I'd machined up a couple of arms for a budget X over kit this is about as strong as I can make this setup
putting in the new longer studs
The lower arm torqued up
Spacer block over the top so the clamping force of the upper arm is transfered to the lower arm not reliant on the studs, note the slot there is a key left in both arms to provide a mechanical advantage
top arm on and 3 out of 4 torqued
Tomorrow night hopefully get the IFS hubs on and axle ready to weld the front X member in
Go the Mothers Utility ....
Cheers Reece
Cheers Reece
