hey guys just wondering if you could tell me if the truck below is a good buy? i dont really know alot about them. does anyone know if it has a turbo or not? what would it be like 4x4n and on road? are they easy to modify? and also wondering of the truck os a base model or not, just wondering because it has no carpet in it.
http://www.trademe.co.nz/Trade-Me-Motor ... 826018.htm
thanks for your help
l200 help
Re: l200 help
not carpet no wet carpet smell, just check to rear gearbox bearing for slop , should be a good driver
Re: l200 help
ok mint, but is it turbo?
Re: l200 help
no my single cab 2wd is non turbo
Re: l200 help
2.8? what does it drive like? because i dont think this one has a turbo in it
Re: l200 help
drives fine, most power under 3000 rpm will rev higher good km/ l but 4x4 will have higher rear gears,had close to a ton and 1/2 in the back still pulled to a 100kph ,
