92 escudo auto radiator in manual ?
wildplumdx
ive found an auto rad but not sure if it will fit my manual ? i cant see why not ?
Re: 92 escudo auto radiator in manual ?
if its out of the same model as your manual it should be fine...the only diffrence between auto and manual rads is the auto cooler tank in the bottom. i have fitted many auto rads into manual cars over the years and never had any overheating problems...
hope this answers your question?
wildplumdx
yup thats what i wanna hear! cheers!!
suzookyman
yup i run an auto one in mine,disconect the two hoses at the
bottom and chuck it in works fine
Al
Al
wildplumdx
awesome i'll be up and running in no time! thats if i havnt cracked the head
suzookyman
its a funny thing about vitara/escas crackin their heads,personely i think
its a good thing.....makes it cheep to pick up f**CED ZOOKS!!!!!!
wildplumdx
yeah thats true, then you can fix it and put a decent set of header on it to reduce it happening again! but i dont wanna spend much on mine, it isnt showing any signs of being cracked so good signs so far!
