Long time lurker, first time poster.
T-Boon
Post by T-Boon »
Hi there
I`ve been lurking on these forums for a while readin up on all sorts of 4wd goodness,
Finally been able to create a user account, for obvious bot reasons etc…
Am going to build up a 1990 surf with a 1UZ and a couple inches of body lift couple inches of suspension and prolly some “33’s then go from there.
To Boon or not to Boon.
lee22
Re: Long time lurker, first time poster.
Post by lee22 »
good luck with the build mate hope it goes well
lee
greetings enjoy the forum please add the area you live to your sig , so we know where you are , then trips and help are not far off :D
T-Boon
Post by T-Boon »
location added :D
Bit of background on me.
I`ve been into drifting for the last few years, but due to limited or no track time, i have parted out my drift car, and decided on 4wding as you can do it many more places.
I’ve built many drift cars (mainly Nissans but a couple Toyota’s), so am familiar with the mechanics behind it all, just gotta get used to lifting a car up instead of lowering it.
Was looking into Safari`s and Suzuki`s but a surf popped up at the right price :D
As above, I’m planning on a surf, I’ve found one off a mate, 1990 v6 (possibly shagged head gasket) so the 1Uz is in order. So far as there`s not a lot of rust in it I’ll grab it, and its only $900. done a lot of research, and the only thing I haven’t planned on is moving the box cross member, but that cant be too hard.
So far the plans :
Surf Body
Celsior 1UZ front bowl sump 404040pin ecu
Custom Sump
Flywheel
Bellhousing
Clutch
1UZ to Surf Engine mounts
Wiring
Log headers and Exhaust
Full Service
Misc - Body lift - PS Lines - Aircon
Then there`s the suspension and tires, but I can get tires cheap (being an ex drifter :D )
Thinking I’ll do a 2 inch body lift, and a couple inch suspension lift, so I’ll need brake lines too. Then I’ll prolly run 33’s so its not too extreme.
Once that’s done, I’ll take her off-road, and see if I wanna look into diffs, or is the stock ones are “enough” which I’m sure they wont be.
All in all I should be able to have the engine in and going for under 6k (including purchasing the car), as the surf is the manual V6 with the handbrake that makes it easy, and the right clutch setup so I’m told.
If anyone can see anything I’m blatantly missing please feel free to tell me, but I think I’ve got most bases covered.
Dan Teeboon
and ofcourse a photo to boot :D
http://img246.imageshack.us/my.php?image=surfev0.jpg
gimmemud
Post by gimmemud »
http://www.marks4wd.com/ is your friend for all your engine stuff. Not cheap but nice kits.
Good luck
gimmemud
Post by gimmemud »
Oh yeah and you missed out the solid axle swap in your list :D :D
SV1K
Site Admin
Post by SV1K »
Welcome and hope you enjoy the place, Coxsy is the one that will keep you informed of trips up your way!
Reece
Smurf
Post by Smurf »
If you can, fit a mid bowl sump. less chance of running out of oil on hills/slope and running bearings
T-Boon
Post by T-Boon »
nah, i`ve looked into it, without a couple hundred mil body lift, it sits on the front diff.
Slideways
Post by Slideways »
Add an Eaton to that list or bust! :lol:
Sad that you sold your Ae86 (or was it 85?), I did the same with my 86 street/club car earlier this year and go into 4wding. Its awesome fun and so much easier to find places to go, well in wellington it is.
Good luck with the build and good job sticking with the trusty 1uz 8)
Only thing I can suggest is possibly upgrading the IRS front because I doubt the diff is going to take much of a beating, maybe change project to a 70 series landcruiser (BIG live axles)?
1985 Toyota Landcruiser BJ73 with 13B-T
T-Boon
Post by T-Boon »
well, a 70 series land cruiser wont be as cheap as the surf, as its more in the first place, and doesnt have all the manual bits i need and i`m guessing the conversion isint as easy.
I may look at building something a bit more extreme later on if i really decide to get into it, or just look at upgrading the diffs and charging the 1u.
But thats a bit off, wanna give it a go and find the limits first :D
and before i really get into the build, i gotta sell my other 180sx, if you know anyone who`s after one, gimme a yell.
Pic.
T-Boon wrote:Image
there we go :D
T-Boon
Post by T-Boon »
got the surf at my place now.
Gotta fix the radistor and see if the V6 is salvageable (blown hg or not) so will prolly compression test it to see.
anyone done a comp test on a 3VZ ? easy to do ?
then if it lives, do body lift, suspension, and tyres, take her out and see if i like her, and go from there.
rokhound
Post by rokhound »
If you have a factory ln130 V6 surf, than you should have the r151 gearbox and 4 pinion 8" rear diff. Both of these are more than adequate for up to 300hp (and maybe a bit more as long as you are not too loose). The 7.5" front diff on the IFS is weak as piss along with the front cv's and these should be the first things you break :wink:
T-Boon
Post by T-Boon »
The chassis code states R150F so i`m guessing its a R150 box?
How do they compare to the 151 ?
rokhound
Post by rokhound »
All the R series boxes seem to be nice and strong.
lexlux
Post by lexlux »
welcome im in auckland as well .
have a look at this all the hard works done what a bargin trade me auction number 196870425 hes his number 027 4223205 .
Toymota2
Post by Toymota2 »
Fancy seeing you on here big T dogg!!
So the magical bottle of copper i sold you got the beast home aye :twisted: .
We can have the sweet battles now :idea:
Mitsi ZR4 E39a
83 Nissan Laurel
SWB V6 Pajero
T-Boon
Post by T-Boon »
lexlux wrote:welcome im in auckland as well .
Hmmn, looks good, depending on price, with that and the cheap surf i`ve got could make a pretty sweet truck.
I asked him to relist, what sort of reserve is he lookin at ?
Toymota2 wrote:Fancy seeing you on here big T dogg!!
Battles on! see u this sunday up Woodhill :D
Chuck up some of the photo`s/vid from last weekend if you want ?
gary_in_nz
Post by gary_in_nz »
hey mate what happened to the truck, not on trademe anymore??
T-Boon
Post by T-Boon »
Bit of an upgrade,
From this :
To This
J_Dub
Post by J_Dub »
you gona remove rear bumper and towbar? did it get in the way at woodhill?
T-Boon
Post by T-Boon »
to be honest, it didnt really, as it just carves a path through the mud,
If i was playing on rocks i might, but at this stage i`ll leave it on. and it makes a easy recovery point, just gotta get under her and make sure the bolts are rated ones, and might add some extra hooks while i`m under there.
not much chassis under your truck at the rear is there :?:
J_Dub
Post by J_Dub »
i stacked my ass end twice on the weekend, bumper been removed, couple big drop offs tho, we did a fair few of the xxxx trails, my rear bar has been a long time in the making, gona have to get the damage fixed once the bar is complete, so im protecting straight panels and not already buggered ones, and nah theres not much chassis to run bars off, not like on your patrol coxsy, rear chassis rail behind bumper. we gota make arms coming off side chassis rails
got to love the long over hang , beat the crap out of mine and its short
UBZ
Post by UBZ »
50x50 4mm box protects the rear nicely.
When you take the rear bumper off the rear of the surf is nice and high up in the air. haven't hung up on mine since the bumper came off.
A receiver type tow bar is a must though.
Spare tyre is a different story though. Need to lift the mounting up proper and mount it to the rear bar.
J_Dub
Post by J_Dub »
gota be long enough for me to sleep in tho, might have to start a thread to see how the dudes in there hiluxes have made there rear bar as strong as possible, i want it that no mater how hard the hit (drop off) it doesnt budge, and move up and hit the body
T-Boon
Post by T-Boon »
yeah, i`ve been thinking of making a swinging rear bar, that holds the spare, and a jerrycan if i want, besides i dont think a 33x12.5 will fit under there. then poss fit a long ranger type fuel tank...
T-Boon
Post by T-Boon »
finally made a build thread.
viewtopic.php?f=18&t=17547
