so i had one of these
after bit of thought and lots of measring verious diff canopys fom utes and surfs and landcruisers i decided on one of these
and it was cheep,hehe
so did this
had to patch the front bit because of the angle the slideing window was on
then had to space the surf canopy up bit higher as the pajero roof is higher so put spacer of bout 14mm under,got some angle on both sides of spacer to seal down on outside and give me mounting points for inside
then had to fleir the top to mach up to the pajero body work
after a lot of cleaning up and sanding,also made a couple mounts for top then fiberglassed over all the bog/patched panels and top mounts,then more boging to smooth out.
then it was up to painting so went black,match the truck and there a kinda black theam of black on my truck,hehe.
have since changed th board in back window to 6mm clear pyspex as that was just a template.
