3.2 v6 oil pressure - please help
Posted: Sun Dec 28, 2008 2:19 pm
the oil pressure seem to be waay too low on my truck, what is likely to be causeing this? oil pump dieing?
edit - kaney under phils name
The opinions and viewpoints expressed by users of Offroad-Express Forums are wholly their own and not necessarily those of Offroad-Express.
https://www.offroadexpress.kiwi:443/Forums/
https://www.offroadexpress.kiwi:443/Forums/viewtopic.php?t=14435
dazza85 wrote:Are you using an electric or mechanical gauge ?
If its electrical it may be a sender fault eiyher way I would check the gauge first ...
Some people have a portable mechanical gauge that they put in where the oil light sender goes to check the system pressure.
If the pressure is low it will be either a worn out oil pump or a worn out motor![]()
