Prado (LJ71) Free wheeling Hub Studs needed asap
Posted: Mon Dec 29, 2008 7:06 pm
by madaz068
Hi,
There are four studs that have a thread on each end. They go into the hub?? and through the free wheelin hub with tapered washers.
I have broken all 4 and the 2 little locator dwells. Does anyone have these as Toyota is saying ex Japan
Thanks
Nick
Re: Prado (LJ71) Free wheeling Hub Studs needed asap
Posted: Mon Dec 29, 2008 9:29 pm
by coxsy
you did, well done :( was tempted to ask how but ?
Posted: Mon Dec 29, 2008 9:34 pm
by madaz068
coxsy wrote:you did, well done :( was tempted to ask how but ?
Towing Nissans out of holes :wink:
Posted: Mon Dec 29, 2008 10:06 pm
by wopass
im pretty sure any hilux,surf,landcruiser with manual hubs are the same studs mate, i know when i blew the hub off my cruiser i used some out of a lux :wink:
Posted: Mon Dec 29, 2008 10:41 pm
by Jerry
the later LJ71's like Nicks and my old pos have those stupid electric hubs, the stub axles and stub bolts are different from memory when I did the manual hub conversion on the old pos.
Posted: Tue Dec 30, 2008 7:04 am
by wjw
Jerry wrote:the later LJ71's like Nicks and my old pos have those stupid electric hubs, the stub axles and stub bolts are different from memory when I did the manual hub conversion on the old pos.
Correct. I gave mine away so don't have them anymore. I've lost count of the number of those stud's I've broken. I used to get replacements from Blacks.
Posted: Tue Dec 30, 2008 8:48 am
by madaz068
Do you have a number for Blacks?? Also what did you replace your hubs with in the end.
Posted: Tue Dec 30, 2008 12:49 pm
by madaz068
Picked up the studs today, hopefully it will be back on the road in the next week. :roll:
Posted: Wed Dec 31, 2008 8:14 am
by hosehustler
Hi Nick,
assuming you still have the electric hubs :?:
here's the solution
best way to cure the problem so it doesn't happen again is to replace the stub axles and hubs with ones from a 70 series cruiser or any solid axle hilux (later the better as less seal wear on the stub axles), they will bolt straight on to your swivel housing, they are the correct length for your prado CV's, you can re use your wheel bearings as they are the same as hilux, and you can bolt your brake rotors on, 30 spline manual FWHubs will then bolt straight on, try and get a set of AISIN ones :wink:
Best set up you can do, and it's really cheap and simple,and it's all bolt on parts :D
Don't bother with the adapter set ups :!:
Posted: Wed Dec 31, 2008 8:46 am
by oldblue
If the studs and dowels are in good condition on the electric type hubs and the nuts at the correct touque then why would going to all of the above be any better?
Only time ive seen the bolts break is when a convesion ring kit is fitted with standard type freewheel hubs on electric main hubs.
Posted: Wed Dec 31, 2008 8:57 am
by hosehustler
oldblue wrote:If the studs and dowels are in good condition on the electric type hubs and the nuts at the correct touque then why would going to all of the above be any better?
So that you don't have the electric hubs, or conversion rings, and of course no custom prats, should you blow a manual FWH if you don't carry a spare then usually someone in a group of 4x4's should have one.
