1.3 zook low comp on No.1 cylinder
Posted: Mon Dec 29, 2008 8:02 pm
Hi,
I recently brought a SJ413 hard top that had a bit of a tired motor. I've done a compression test on the motor and from front to back:
No.1: 105psi
No.2: 210psi
No.3: 210psi
No.4: 210psi
When i did the compression test I did all cylinders twice and the motor was at operating temperature when I did the test. On cylinder 1 I thought it might be sticky rings so i sprayed a heap of degreaser down the spark plug hole and let it sit for an hour then cranked it over to push the excess out so i didnt get a hydralulic lock. I did a comp test afterwards and no change.
The motor doesn't idle well but will run when held around 1200rpm and will rev freely to redline. It also seems like it runs nicer the higher the revs are held. It doesn't blow any smoke out the exhaust although it does blow smoke out of the crank case breather. I also pulled the rocker cover off to see if I had cracked a valve spring but they all looked ok. Coolant in radiator seems good and there is no water in the oil and doesnt really seem to be burning oil in the short time I had the engine running.
Are there any other tests I can do without having to dismantle the engine. Do these symptoms sound like a burnt valve or something similar? Did putting the degreaser down there and then testing give me a true wet test for rings or should I do it again with some oil?
Thanks,
Paul
No.1: 105psi
No.2: 210psi
No.3: 210psi
No.4: 210psi
Thanks,
Paul
