first up, high lift jack mounts made up from old knackered leaf spring bushes and some tube off cuts
next up power supply in the cab made up from an old set of booster cables, some buzz bars from an old consumer unit(home electric switch board) and a used water proof junction box that was lying arround in the stores. i done this so i didnt have loads of small wire attached to the batteries
so there you go recycling at its best, now lets see what old/odd stuff youve made use off on your motors
lee
