Fj40 Leaf Springs with Exteneded Shackles into a FJ70?
Posted: Sat Jan 03, 2009 4:50 pm
by Bubba
My knowledge is limited on this subject so please beer
with me
My fj70 has crap travel (articulatioon) compared to a fj40 and it my understanding is because the leaf springs are shorter on a 70. I would like to get more travel while also spending sweet FA.
If the 40 has longer leafs why can't I replace the 70 pack (or at least some) with a 40 pack, with an extended anti inversion shackles. Has it been done? I would have thought if it was do-able it would be a cheap (if not slight) upgrade.
Re: Fj40 Leaf Springs with Exteneded Shackles into a FJ70?
Posted: Sat Jan 03, 2009 5:50 pm
by Jerry
maybe see what Rob can do on a new EFS suspension?, he may be able to source drop shackles?, otherwise can JAFA make you some ?
Posted: Sat Jan 03, 2009 7:37 pm
by wopass
i dont know about the 70 springs being shorter than the 40 but i did put 60 series springs in my 40 which were a lot longer than the 40 springs and put much longer shackles on to take up the difference, this gave it a much softer ride and much more flex droop wise, compression was the same as it was still the same height so if the 40 springs are longer than the 70 springs i would say go for it.
did Jerry actually read your post? im sure it says in the you want to spend SFA... new EFS set??? what the hell??? even a mates rates off the back of the truck in the middle of the night wouldnt be SFA Jerry you TOOL!
Posted: Sun Jan 04, 2009 1:23 am
by Kempy
Im interested to know how you get on with this idea. Keep us updated if you get a chance. If it works I might look into doing it myself. Seems feasible in theory yeah?
Kempy.
Posted: Sun Jan 04, 2009 11:25 am
by mickey
don't know about the front, but the rear 70 series are longer than the rear 40 series.
pins are in different places as well, further back on a 70.
ironman suspension has the specs of their springs on their website, so you can compare.
Posted: Sun Jan 04, 2009 7:31 pm
by Bubba
Can anyone tell me the lengths of the 40,60 and 70 main leafs?
The main downfall of the 70 is the front axel so fitting longer rear ones in the front would resolve this, however from what Whoop says, 60 springs are longer.
Do 60 springs fit 70's?
Just need to find me some scissor shackels now
Posted: Sun Jan 04, 2009 9:07 pm
by cruzerboy
Ive got 60 springs in the rear of my cruiser there the same lenth as 70s mine are just saged two fark flexs good tho
prity shore 60 front ones are the same as 70s fronts dont know about 40 ones tho
Posted: Mon Jan 05, 2009 8:30 am
by Bubba
Sooooo, if the 60's are the same as the 70's and the 60's are longer than the 40's that makes the 70's longer than 40's which dosen't explain why 40's have more flex than 70's except to factor in the other two points, old soft leafs and shocks.
The last two points I can't do much about on my budget at the moment
Posted: Mon Jan 05, 2009 9:50 am
by MNC
Bubba wrote:...Just need to find me some scissor shackels now
I'd be keen on a set if someone was going to organise an ORE group buy...
Posted: Mon Jan 05, 2009 10:52 am
by Bubba
Apprently scissor arn't that hard to make.... Well actually I should say they are apparently not hard for SOME ONE esle to make.
POI: The rear ones should also have sideways flex but not the front ones. Screws with your road handling so I am told
This is a exercise in education and finding out what I can, should do as opposed to what I will do tomorrow. I know there is the stock standard way of doing things (longer shackles, longer shocks) but I always like to know "why do you do it this way?" and "why can't I do this other way?"
Posted: Tue Jan 20, 2009 7:38 pm
by Big
cruzerboy wrote:Ive got 60 springs in the rear of my cruiser there the same lenth as 70s mine are just saged two fark flexs good tho
Hey dude..you got some great artic there..what shocks do you use..?
Posted: Tue Jan 20, 2009 8:23 pm
by sig
here is a link to a site with the different spring lenghts /widths etc for 40/60/70/80 cruisers
http://www.off-road.com/trucks4x4/artic ... ?id=264199
