Bearings
For all Daihatsu related topics.
southland_Feroza
Bearings
Post by southland_Feroza »
G'day. I'm needing to change my left rear wheel bearing in my 1990 feroza. Has anyone done this job and is it possible just to do it myself????
meece4x4
Re: Bearings
Post by meece4x4 »
gdday southland_feroza
Sorry cant help you on the rear wheel bearings, never had to do one while i owned my Fez, however if you have a basic set of tools (ring open end spanners and sockets) i cant see why not, most of the stuff i DID do on the feroza was reasonably straight forward :D
If you havnt downloaded it already grab the Feroza Service Manuals off the Warfs site
http://www.warfs.org/content/view/16/47/
these will give you all the info you will need on these little beasties.
just as a matter of interest what sort of symptoms does yours have?? is it rumbling or making funny noises?? only reason I ask is I do know that it's not uncommon for the Feroza to have a little bit of end play (able to grab the rear wheel and move it in and out a few mm, I thought my bearing where gone when i saw that but was told that they where fine and my mates one had about the same amount of slop??? :? drove it around for another 40000k's before i sold it and didnt make any funny noises or have the wheel fall off or anything else just the end play.
southland_Feroza
Re: Bearings
No its has no play in it. Just a rumbling noise. it only makes the noise on one side as well. Thanks for the website link. Should be helpfull.
cool__bananas
Re: Bearings
Post by cool__bananas »
some wheel bearing are pressed onto the axle so you will need a press
benorange
Re: Bearings
Post by benorange »
i got my diffs all pulled to bits at mo if you want to come have a look. and i got a copy of the workshop man. let me know and ill give you a txt if you want.
Return to “Daihatsu”
