Bearings
Posted: Mon Jan 05, 2009 5:58 pm
by southland_Feroza
G'day. I'm needing to change my left rear wheel bearing in my 1990 feroza. Has anyone done this job and is it possible just to do it myself????
Re: Bearings
Posted: Tue Jan 06, 2009 4:19 pm
by meece4x4
gdday southland_feroza
Sorry cant help you on the rear wheel bearings, never had to do one while i owned my Fez, however if you have a basic set of tools (ring open end spanners and sockets) i cant see why not, most of the stuff i DID do on the feroza was reasonably straight forward
If you havnt downloaded it already grab the Feroza Service Manuals off the Warfs site
http://www.warfs.org/content/view/16/47/these will give you all the info you will need on these little beasties.
just as a matter of interest what sort of symptoms does yours have?? is it rumbling or making funny noises?? only reason I ask is I do know that it's not uncommon for the Feroza to have a little bit of end play (able to grab the rear wheel and move it in and out a few mm, I thought my bearing where gone when i saw that but was told that they where fine and my mates one had about the same amount of slop???
drove it around for another 40000k's before i sold it and didnt make any funny noises or have the wheel fall off or anything else just the end play.
Re: Bearings
Posted: Tue Jan 06, 2009 6:30 pm
by southland_Feroza
No its has no play in it. Just a rumbling noise. it only makes the noise on one side as well. Thanks for the website link. Should be helpfull.
Re: Bearings
Posted: Tue Jan 06, 2009 8:28 pm
by cool__bananas
some wheel bearing are pressed onto the axle so you will need a press
Re: Bearings
Posted: Sat Jan 10, 2009 3:31 pm
by benorange
i got my diffs all pulled to bits at mo if you want to come have a look. and i got a copy of the workshop man. let me know and ill give you a txt if you want.
