LSD
For all Nissan related topics
southland_Feroza
LSD
Post by southland_Feroza »
Does a 1988 Nissan safari grandroad long wheel base truck have a limited slip diff???
safaripete
Re: LSD
Post by safaripete »
yes
J_Dub
Re: LSD
Post by J_Dub »
do a skid and have a look :D
jack up the rear turn a wheel and if both turn same direction it does have l.s.d
safaripete
Re: LSD
also there should be an orange sticker on outside of diff
but yeah 9/10 safaris have rear lsd :D
Safari Swb
Re: LSD
Post by Safari Swb »
are the factory lockers any good? theres a couple of setups on trademe along with al the vacuum lines
89 safari swb-4.2 auto..for sale
96 safari swb-2.8t manual..stock
safaripete
Re: LSD
Safari Swb wrote:are the factory lockers any good? theres a couple of setups on trademe along with al the vacuum lines
not sure how they go personally
but we cut the vacum lock centre housings out at work and put rangerover ends on for a guy here in palmy and his truck is a serious offroad machine
so they must be the goods
cool__bananas
Re: LSD
Post by cool__bananas »
they are good but have a problem with stripping the gear inside so after a while it just keeps popping out under any load at all.
Re: LSD
well when i fit this locker diff I've got will keep the lsd as spare :D
gary_in_nz
Re: LSD
Post by gary_in_nz »
actually another question about lsd's, can i fit an arb locker to my LSD diff??
cool__bananas
Re: LSD
gary_in_nz wrote:actually another question about lsd's, can i fit an arb locker to my LSD diff??
yes because when you change inbetween open, lsd, locked or whatever all you are doing is changing the center carrier of the diff (where the spider gears are) although dont quote me on expensive things :lol:
Bubba
Re: LSD
Post by Bubba »
Is that the same for all diff's (Toyota/Nissan), I thought ARB could only be fitted to open diff's.
Benjamin Franklin
turoa
Pyro Junior
Re: LSD
Post by turoa »
you thought wrong
Bubba
Re: LSD
Post by Bubba »
Ouch! Harsh Tu, harsh
Benjamin Franklin
cool__bananas
Re: LSD
well i had a suzuki with a lsd and i put a arb in it with the same diff
Bubba
Re: LSD
Post by Bubba »
ok ok i get the point jezzzzzz, no need to bash me to death with it and then carve into my headstone :D
I'm allowed to be wrong now and then arn't I?
Benjamin Franklin
cool__bananas
Re: LSD
Bubba wrote:I'm allowed to be wrong now and then arn't I?
no :lol:
