Howdy all!
Simon here from palmy north. Some of you may know me as trademe name "nomis9".
Just thought I'd introduce myself and say gidday.
I've got a rover powered homebuilt D class trials truck that I used to trial and am in the process (admittedly very slowly at times) of building a more competitive C class truck.
I deal in hilux/surf diffs and other parts as well when I have them, mainly 80's and early 90's parts. So if your after some parts let me know. I usually have 4.3, 4.5 and 4.8 ratio heads and front and rear housings in stock.
Greetings fellow petrol heads!
Re: Greetings fellow petrol heads!
Well, I'll welcome ya if no one else does... Welcome!!
Welcome, im sure there will be a few people after diffs at times.
ps---pics of your trucks
toymota thats stock standard.
welcome to ORE, definatly get some pics up
how much for ya 4.88 dif head?
99 pajero exceed 3.2
basics wrote:welcome to ORE, definatly get some pics up![]()
working on the pictures
$150-180 each for 2 spider open heads, depending on which era they come from. only got earlier ones in 4.8 at the moment, (lighter housing so not quite as strong as later ones, still fit in all the same diff housings tho).
Got plenty of 6 stud rear housings and axles if any one wants a spare set. $60 each complete with housing, axles and brakes. I've got both surf width and hilux width and the surf ones in both leaf sprung and coil sprung setup.
