forward shifting hilux transfer box wanted.
i have a top shift if anyone wants it...
Ryan
LN130 Surf: Coiled SAS, 35" BFG M/T's, Lifted, Rear Lockright, Snorkel, CB, On-board air
Soon to be 3.8 commy powered, front ARB Air Locker, custom bar work, winch...
Re: forward shifting hilux transfer box wanted
I told you I want the top shift!
you dont need it your going lexus! besides if someone wants to swap top shift for forward then ill be doin that if not then i guess maybe u could probably have it...
children, children, children......
still need one
Hey mate I've got a couple of trans cases off hilux's/surfs. which series gearbox is the one you want off? I've got a R series and a W series and another one that I'm not sure what it came off.
Cheers Simon
Cheers Simon
no idea man i just know its meant to be off a lateish 1980s beam axle hilux!
Engineer wrote:no idea man i just know its meant to be off a lateish 1980s beam axle hilux!
g56 box apprently
Kiwi4x4
vvega wrote:Engineer wrote:no idea man i just know its meant to be off a lateish 1980s beam axle hilux!
g56 box apprently
awesome thanks man
na g52 gearbox is weak and has front shift transfercase off 1980s hilux's, beam axle surfs
and some early 90s ifs hilux's
w56 is stronger and has the topshift transfercase from the mid to late 80s turbo surfs
i realise you only want the transfercase but i thought this might help you out in your search
