auto sparky / radio installer
fweddy
Post by fweddy »
I have a AM CB in my truck from when I got it, I don't think it is connected up properly as I don't get anything on it like I did when I first got it (bad connections I believe)
Also recently I got myself a basic UHF unit (Uniden UH-011 UHF PRS) which I need to install. (plus get a suitable aerial) - has any one here done the scan mod to one of these?)
Also my CD deck needs to be wired through with a continuous feed as every time I turn the truck off it resets. (might be complicated as its running through a reducer (24-12v)
Is any one around this area competent to give a hand one day/evening with something like this?
madaz068
Re: auto sparky / radio installer
Post by madaz068 »
Easy to do mate, just decide on where to mount, and run the cable from the aerial (you need a sep one for the UHF), to the unit. You will have to push through a rubber on the firewall.
Next find a good earth. Im guessing your truck is 24 volt, so you will need to run from one of the batts
Next you need a positive. If you want to run while the key is off, run a lead from one of the batts (same as the neg), otherwise you need to run a relay system.
Any questions drop me a PM
fweddy
Post by fweddy »
radar21
Post by radar21 »
the second one for sure
scott gibson
MudBum
Post by MudBum »
Hi Fweddy
Have a mate who's a sparky if ya need some help,PM me and let me know.
Return to “Tool Shed”
