ln130 gearbox in ln106
brakes-shocks-lockers-etc
bigstu
Post by bigstu »
mate of mine blew his g52 box and is looking into a r150? he mentioned some thing about geting round the electric
hubs does anyone no what you have to do to get one of these boxes into his hilux?
Thanks Stu
blulux
Re: ln130 gearbox in ln106
Post by blulux »
i do
behind my 2jz i have a solid axle one so not sure on the wiring for the vac but i do have the hilux book i can send you a copy of the page if you want,
when you get the r150f/r151f you will need the loom and the 4wd ecu, (its under the radio),
i just have an in and out switch and hold them down till it clicks (just temp at the mo)
give me a call or a txt, 0211203155
scott
good luck
1991 Hilux ,solid front axle ,3.0 2jzge,crane
