Low profile bump stops and TDC
Posted: Sun Feb 08, 2009 8:22 pm
Hi team,
Have completed ball joint flip, front suspension kit, torsion bar wind up and shaved the top bump stops. Can/should I shave the lower bump stops or can you buy low profile bump stops. I have seen a button type bump stop advertised overseas but unsure if you can get them here. Or alternatively what is a suitable amount to shave the lower bump stops?
Also had the valve stem seals done in place, but since they were done I have noticed a distinct lack of power. Unfortunately the chap who did the seals has now left the country. It has been mentioned that as he did them in place that its possible one of the cams has gone back in a tooth out. Does anyone know of a simple way I can determine if thats the case or not. Or is it back into the shop?
Rod
Rod
