GQ drag link
Posted: Tue Feb 10, 2009 8:17 pm
by 63swb
hi,
My safari failed its warrent on excessive play in the ball joints on the drag link, just wondering if these can be replaced or does a whole link need to be sourced? looks like it is all one solid piece? any help would be appreciated.
Re: GQ drag link
Posted: Tue Feb 10, 2009 8:49 pm
by Safari Swb
yep mynes all solid . bnt should be cheapest
Re: GQ drag link
Posted: Tue Feb 10, 2009 8:51 pm
by Lynx
Hey, Some Are Solid but ii have seen a adjustable/seperate tie rod unit. Have seen both come from partmaster
Re: GQ drag link
Posted: Wed Feb 11, 2009 9:44 am
by GQTROL
63swb wrote:hi,
The standard draglinks infront of the diff on GQ wagons are one-piece units and are generally not rebuildable (although it can be done). Replacement ones are available from Nissan for lotsa $$.
You can get rod ends though, so if you know a helpful Nissan branch that can find the part number for you, they should be about $150 each. Alternatively, do a search on here as I've posted the part numbers many times previously.
EDIT: Here are the #'s ....4852-001J10 and 4857-001J10 for left and right hand
Re: GQ drag link
Posted: Wed Feb 11, 2009 10:05 am
by darinz
Are they the part numbers for the GU rod end?
Re: GQ drag link
Posted: Wed Feb 11, 2009 11:22 am
by GQTROL
darinz wrote:Are they the part numbers for the GU rod end?
Nah, just GQ. GU have different bolt dia and taper. These will work on the bigger GQ box though like yours.
Re: GQ drag link
Posted: Wed Feb 11, 2009 4:50 pm
by 63swb
thanks for the help guys, i thought it might of been difficult to rebuild them so ill have a look around to see what i can get
Re: GQ drag link
Posted: Wed Feb 11, 2009 6:31 pm
by DaveM
Maybe worth looking at a custom one?
Re: GQ drag link
Posted: Wed Feb 11, 2009 6:47 pm
by 4WDbits
DaveM wrote:Maybe worth looking at a custom one?
At the risk of being acussed of plugging, we have these
http://www.4wdbits.co.nz/ProductDetails.aspx?productID=1313
Re: GQ drag link
Posted: Wed Feb 11, 2009 6:54 pm
by coxsy
yes, but looks good and priced well
Re: GQ drag link
Posted: Wed Feb 11, 2009 7:05 pm
by DaveM
At that price,I'll be in touch when I get the GQ going
Re: GQ drag link
Posted: Wed Feb 11, 2009 8:39 pm
by flyingbrick
Are these ball joints and cromolly tube rather expensive? I dont get how that could cost nearly $300.
Not trying to take the piss.. just curious.
Re: GQ drag link
Posted: Thu Feb 12, 2009 7:47 am
by GQTROL
flyingbrick wrote::?
Price a factory (i.e. weak as piss) draglink from Nissan...not much change from $800! So one (or even two at that price) of 4WDBits chromoly units is cheap as chips!
Re: GQ drag link
Posted: Thu Feb 12, 2009 7:54 am
by Swamped
Those look the same or quite similar to the ones on trademe. My factory ones have grease nipples on em though too, is that not necessary with the cro-mol ones??
Hopefully thats not a stupid question
Re: GQ drag link
Posted: Wed Jan 13, 2010 1:52 pm
by Patroler
HBI Engineering in ChCh recondition them for approx $195 incl (both ends)
Re: GQ drag link
Posted: Wed Jan 13, 2010 2:42 pm
by darinz
Patroler wrote:HBI Engineering in ChCh recondition them for approx $195 incl (both ends)
The only problem with that is it is always the top balljoint at the steering box that dies and the one at the diff is still OK. One with rodends like Warren sells are the way to go. Much cheaper to buy and when one end packs up just replace that one at about $50.
Re: GQ drag link
Posted: Wed Jan 13, 2010 9:29 pm
by Shane
Two of my friends have brouhgt the chromoly tie rods from 4wdbits,good price IMO and no more bent tie rods every coast trip,they look well made to me.
Shane
Re: GQ drag link
Posted: Sat Jan 16, 2010 10:14 am
by 4WDbits
We're not selling Chromoly tie rods and drag links any more, once bent they would cracked when straightening which made it dangerous to keep driving. We have heavy duty mild steel ones now, still adjustable with replaceable ball joints. They can also be straightened and are safe to keep using, but like anything will eventually crack with repeated bending back and forth.
