A mate suspects he's blown all the shocks on his diesel rocky. Solid axle with leaf springs front and rear.
Are they interchangable with anything else that's remotely common?
Diesel Rocky Shocks.
Re: Diesel Rocky Shocks.
solid axle Rocks *Should* be the same as the Toyota Blizzard ... id' whip a front and rear shock off and check tho, as im not 100% sure,
My old F300 Narrow track had 89' Commodore wagon rear shocks in it, I just went to a local wrecker and after explaining what i wanted let me fossick through his shock bin till i could match shock lengths
I have replaced mine with some out of a commadore aswell they are about 20mm longer thats all,
but if you want longer ones I've been told hilux ones are the go
Cheers guys.
First thing I guess is to pull them off and see which ones are dead.
iv got a set of monroe shocks for one of these that i took out to upgrade to bigger ones if you after some let me know
benorange wrote:iv got a set of monroe shocks for one of these that i took out to upgrade to bigger ones if you after some let me know
I'll pass that on. Whereabouts are you?
invercargill
set of hilux shocks will do fine, just have to change the lower mount bush to one with the correct diameter hole through it
cameronmaxwell@xtra.co.nz
0274202727
0274202727
