Wanted rear surf LSD
im looking for a rear surf LSD if any one has got one, let me know ya price.
90' 2.8 Hilux Surf
0272543646
0272543646
Re: Wanted rear surf LSD
Might have one. What year Surf and what ratio? Axle code is on the chassis plate or count the teeth on yours.
Matt
Matt
Hey yep got a couple of them, what ratio are you after? check your axle code on the ID plate, it will be G254 or G282 or similar, this will tell us the ratio.
its g282 and also are they interchangable ie swap front and rear no problems?
90' 2.8 Hilux Surf
0272543646
0272543646
282 means you have 4.3 ratio 2 spider (non LSD) diffs.
Surf front diffs are F series and smaller than the rear (G series) so no not interchangeable, hilux's have solid front axle and the same sized diff heads front and rear.
I have a good 4.3 LSD for the rear of your surf. $300
cheers Simon
cheers Simon
so what you are saying is get me a solid front axle from a hilux and drop that in aswell (which i plan on doing one day) do you know if there are any troubles with doing this?
90' 2.8 Hilux Surf
0272543646
0272543646
get a quote then ad 3k on top happened to me lol
i think i will just leave it ifs for now, does anyone have a LSD lying round for the front IFS then
90' 2.8 Hilux Surf
0272543646
0272543646
There isn't a factory LSD for the front, you are better to drop an auto locker in there.
