OMG!! No one has starded one..... for this weekend
SV1K
Site Admin
Post by SV1K »
It all strarted with Curly12 breaking down in McD's (lower hutt) drive through on Friday! hahaha he didn't even get his toy!
(Friday) Took William's new (old) POS over the Masterton (area) and that was a comedy of errors from the start! After one flat tyre, one broken strop and a quick tea stop we managed to get there at 10:30.. not bad considering that we started loading the thing up at 6:30! back home by 1am..... (bloody thing has two hand breaks... not easy to tow with one of them on...
(Saturday) Picked up Jerry's new body... no for the truck not his head.... pic's will be up latter...
Now for the next mission.. PR's welder to the freight company! will be there by tomorrow PR (if you read this)
8)
Re: OMG!! 14/15 Feb No one has starded one..... for this weekend
New Doner Lexpos Body :D
is straight and has a nice undamaged (and unmelted) loom
Huge Thanks to Reece for helping me with this, and Graeme from Classic Cars for the Trailer loan, and the Shiny truck for towing new parts for its brother :D
At reece's place the Abbo twins turned up :D
PR
In the crap again
Re: OMG!! No one has starded one..... for this weekend
Post by PR »
suzuki1k wrote: Now for the next mission.. PR's welder to the freight company! will be there by tomorrow PR (if you read this)
8)
(021) 02388443
xj
Post by xj »
Changed front pinion seal. During the process, aftert aking off the yoke nut... a funny smell followed.... the smell of rotten oil. Popped the front diff cover off and was met by a slow moving, nearly gelatinous mess of brown oily stuff, which probably wasn't doing too much good for the locker.Tidied everything up and replaced with nice clean gear oil.
also figured thast while i was there that i may as well fit my replacement upper front control arms.... stock versions with some reinforcing added. After much cussing and a little bit of blod spilt, i have decided that the clown that designed the "locking tab" was nothing short of an in bred, 6 fingered, banjo playing 'tard. Why they didnt just do like the rest of the world does and put a bolt through and flick a nut on the threaded end i just dunno.... "It's a (farking screwed up) Jeep Thing". The only way to get the bloody thing off was to take the blade out of a hacksaw and suffer cramp while trying to saw through the bolt, then bang the bolt out.
These two jobs took the better part of 7 hours...... we are not amused.
Still yet to remove the yoke from the transfer case output (sye) and repalce the seal and the little rubber washer at the end of the yoke. When going uphill the atf finds its way up the thread, passed the yoke and spins out of the yoke nut all over the underside of the wagon, including the exhaust...........
................. wheres my noose...................
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
J_Dub
Post by J_Dub »
fitted extended brake lines, got em made up 200mm longa at $40 each, and fitted new steering dampner, all vibration gone in the steering now, now im looking at buying another surf, 130, for me daily driver, pain in the ass working on the truck and stressing to have it ready and sweet for the working week, found a friken tidy 2 door 130 for 2k, may go have a look tomorrow, who knows, might lead to a sas
Perhaps Mark could explain this ... something about a wheel falling off :shock:
basics
Post by basics »
eventful weekend so far, best stay at home judging by all the welly pics
99 pajero exceed 3.2
TJ
Post by TJ »
xj wrote:Still yet to remove the yoke from the transfer case output (sye) and repalce the seal and the little rubber washer at the end of the yoke. When going uphill the atf finds its way up the thread, passed the yoke and spins out of the yoke nut all over the underside of the wagon, including the exhaust
You are supposed to put a little bit of gasket sealer on the spline inside the yoke before fitting it on the back of the transfer case. Also to the back of the yoke nut. At least that is what the instructions were on my SYE. No leaks yet, after driving for over a year now. ATF is very thin (particularly when hot), so it can go past a very slim margin of error between machining.
PS: Have you changed your job? Sent a text to your work phone and got an interesting reply!!
abbo
Post by abbo »
Have had a good one so far... :D I got the pto in and thanks to curly we (he) rebuilt the rear brakes on the cruiser.... :twisted: Its has a hand brake now.... :lol: :lol: . All so got little rust repairs done. All so played driver for curly to find the parts for his pos whale........ :lol: :roll: :mrgreen: Tomorrow drop the oil in gear box and do the front brakes....abbo :mrgreen:
Don't have 4wd.
xj
Post by xj »
021475822... new job back in June. One of my old staff now have my old phone, he's a cheeky bugger
Apparently the little rubber star washer in behind the yoke fails, and this is the exact thing that happens. Ill be replacing the pinion seal, the rubber star washer (got them all here as spares) and gasket sealing the whole deal. Did it all right the first time too, but i guess just not efficiently enough.
/| , [____],
l----L -OlllllllO-
()_) ()_)-----)_)
KEEP'N JEEP'N!
TJ
Post by TJ »
xj wrote:Apparently the little rubber star washer in behind the yoke fails, and this is the exact thing that happens. Ill be replacing the pinion seal, the rubber star washer (got them all here as spares) and gasket sealing the whole deal. Did it all right the first time too, but i guess just not efficiently enough.
Mine never came with a star washer. Must be a slightly different design for the yoke.
lneil
Post by lneil »
Worked today, then swapped the 30" muds off the 5-door when I got home. Replaced with the factory road-wheels and I really hate the way it looks now!
Still got to swap out the front diff in the yellow beast and try to get the rt/front suspension shoved somewhere back towards where it's supposed to be, plus fit guard flares to the piglet. Tomorrow will probably not be productive though, as I have to take daughter No.2 into town for some driving practice before her test on Tuesday.
wopass
Post by wopass »
did some work on the cage then did some work on a Gbox for a mate.... bit more involved than i thought it was gonna be :roll:
my cage finished :mrgreen:
someone who shall remain nameless's Gbox swap job
where do these bits go again??
SV1K
Site Admin
Post by SV1K »
Well the welder is loaded in the back of Jerry's shiny POS ready for delivery to the frieght company tomorrow! It's almost on it's way PR!! WOO HOO!
8)
PR
In the crap again
Post by PR »
SWEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEET :mrgreen: 8)
(021) 02388443
Curly was moaning about the steering in my truck when we were up in the hills last weekend so I though I better see what was up :oops: :oops: :mrgreen:
J_Dub
Post by J_Dub »
just purchased new truck, daily driver, so now the surf can sit all week ready and waiting, and i can drive to work in a nice clean cabin, enjoying the nice soft ride of a coiled and ifs surf. its a 89 2 door surf 230ks, real straight, rust free, injected 3y, goes mint $1800
did stadia tracks as a shinny trip
J_Dub
Post by J_Dub »
dam i should have gone to Stadia, looks as tho was a mint day for it, plenty a mud still, looks as tho some a the guys thought was an actual shiney trip judging by there small tyres
vvega
Post by vvega »
rebuilt the front axel in the lux
new bearings swivils and finally some freewheeling hubs :d
its a 4WD again :d
next weekend it gets new vented rotoa's and a cert .. hopefully
Kiwi4x4
albundy
Rolly Polly
Post by albundy »
Finished off my cargo/storage holder on Saturday and did the Poulter river via the upper waimak today. Finished off with a few cold bevies at the springfield pub :oops: that's not allowed anymore, PC brigade took over :wink:
al
wopass
Post by wopass »
vvega wrote:rebuilt the front axel in the lux
its a 4WD again :d
you get it all sorted mate? choice!! if i get my shocks this week there might have to be a quick blat somewhere next weekend :mrgreen:
Mud Hog
Post by Mud Hog »
Managed to stuff the auto in the Wamak river and had a tyre come off rim while I was stuck in water over my stomach in the cab. Lucky was with a good mate with a good truck to help me get out of the shit. I think a recovery group would be a good back up resource. We both had reasonably set up trucks but when shit goes bad it goes real bad. Well that was my achievment. Hopefully wiser for it.
GU patrol 35s ect.
spanky
Post by spanky »
me and the kids went for a play in the river, bugger all else as getting my 61 plymouth hearse ready for mates wedding next weekend, this pic from last weekend up bush.
vaughan
vvega
Post by vvega »
its a 4WD again :d
all good if not i have some spongy blocks of wood we can jam in there :D
Kiwi4x4
86-surf
Post by 86-surf »
well my acheivement for the weekend was putting my fan through the radiator... lucky i had a few friends following me otherwise i would have a cooked truck!.
no looking for a radiator and fan for a 2.4t diesel!!
86-surf wrote:well my acheivement for the weekend was putting my fan through the radiator... lucky i had a few friends following me otherwise i would have a cooked truck!.
are you working Jase?????
could you be in taupo at lunch time on friday???
I may be able to help
86-surf
Post by 86-surf »
i work friday night, i have a day off work soon so i can be in taupo on friday.
how can you be of service skidy?
86-surf wrote:i work friday night, i have a day off work soon so i can be in taupo on friday.
flag that
got ya hopes up
flatmate just wrecked a surf, but he just informed me the radiator is sold
sorry
86-surf
Post by 86-surf »
allgood, thanks for the offer any ways!
