gearbox oil change
Posted: Tue Feb 17, 2009 1:25 pm
by tracta
Hi all
needing to a change/ top up of the gearbox oil, anyone know how much ill need ? its a 91 nissan terrano diesel. I know about filling through the gear stick as the filler isnt high enough, just not sure how many litres to put in ?
Re: gearbox oil change
Posted: Tue Feb 17, 2009 2:50 pm
by albundy
go to the shell lube match website, fill in the blanks and hey presto, every volume you need to refill everything on your rig.
Al
Posted: Tue Feb 17, 2009 3:45 pm
by gary_in_nz
that site is a bit vague on safaris
http://www.shell.com/home/page/nz-en/sh ... _1128.html
Posted: Tue Feb 17, 2009 5:27 pm
by Safari Swb
i will find out for you tommorow
Posted: Tue Feb 17, 2009 7:14 pm
by long
The required weight of oil for the manual gearbox is 75/90w the required amount depends on the gearbox for the FS6R30A gearbox you will need 3.6liters of oil for the FS5W71G/C you will need 4 liters.
Hope this helps you out
Posted: Tue Feb 17, 2009 9:41 pm
by tracta
thanks guys.
