32" Maxxis on Smurf...
Posted: Tue Feb 17, 2009 3:35 pm
by SmurfN
Hi guys
I am new to this forum as I have just recently purchased a 4wd... an 85 2litre petrol 5 speed surf. Solid beam axle... (I hear these are better than IFS for 4wdin???) It has only done 173 original kms and has never been offroad... Bit of a score i think for wanting a standard one to build up...
I am a member of other car forums and have been for years but now my interests have changed, well grown, and I am delving into the unknown world of 4wding...
ANYWAY... My smurf came with crap as road/maybe but probably not 4wd tyres with bugger all tread and I have the option of purchasing some Maxxi Buckshot 32s for pretty darn cheap off a mate. I have a 15inch rim on the smurf at the moment so will wrap the Maxxi's around those if I decide to purchase...
As I am only getting into 4wding I take it these tyres will be ok? No clearance issues with a smurf?
Appreciate peoples comments...
Ta
Re: 32" Maxxis on Smurf...
Posted: Tue Feb 17, 2009 3:42 pm
by lil_tank
u shouldnt have to many problems with clearance i had a set of 32s on a old ifs surf i had
yours factory should allready have a soa so can invisage any problems unless ure leaves have sagd
Posted: Tue Feb 17, 2009 3:53 pm
by abbo
Hi there one of the wellington guys had a thing for surf's :roll: and it was ifs so with the beam axle you are much better off. He had 33's on it with no problem. The buck shots are not bad but what sort of driving you want to do grass,sand mud.....To start of with they will do the trick. There are trips coming up so keep a eye out on here and come along......cheers abbo :mrgreen:
Posted: Tue Feb 17, 2009 4:40 pm
by radar21
ive got 32" buckshots on my ifs surf and only get a little rub when turnnig and cross axleling at the same time you will be fine
Posted: Tue Feb 17, 2009 6:11 pm
by SmurfN
Sweet sounds like a plan then :D
I plan to use it whereever i can... mud, water, sand. My mate has them on his vitara and they pretty sweet on that and he takes it all over the show
Posted: Tue Feb 17, 2009 7:23 pm
by radar21
year they not a bad tyre make sure thay still got the sharp edges
Posted: Tue Feb 17, 2009 8:38 pm
by J_Dub
ive got 33" muds on standard height, sits fairly high tho, so if yours aint sagged should be sweet, remove rear bumper, front bumper skirt/valance, and flatten out the sharp bits in front inside guard
Posted: Wed Feb 18, 2009 11:58 am
by Steve_t647
There is a seam in the back of the front fender (in front of the drivers feet) that will want some massaging flat with a hammer otherwise it can chew your tyres, this was for 33's and at full stuff you will get some rub, the standard leaves are pretty flat and love to go negative (invert) most after market leaves with lift have a bow in then so cannot go negative or if they do soon droop so when replacing springs for long life look at the bump stop.
Posted: Wed Feb 18, 2009 5:38 pm
by SmurfN
sweet i got the 32s on there today and just went for a drive and they seem to be sweet... no rubbing at all at full lock or nothing so seem to be all good... :D will get some pics up soon
Posted: Wed Feb 18, 2009 6:58 pm
by Jerry
howdy, theres a trip 1st march if you are keen
also theres a training day planned if you are keen (just waiting on enough numbers) viewtopic.php?f=26&t=14540&p=171574#p171574
Posted: Wed Feb 18, 2009 7:37 pm
by SmurfN
yeah i could be keen will see what happens closer to the time as am a busy lad!
have tried uploading pics using the help bit on photo albums but it doesn't seem to be working. on other forums i have posted pics in you can upload to imageshack or the like and post a link for it to display in your post... any ideas if this works here?
Posted: Wed Feb 18, 2009 7:38 pm
by Jerry
yeah it does, just use the img button
Posted: Thu Feb 19, 2009 8:23 pm
by SmurfN
some pics that i just took with new tyres. wheels were white but got them painted black. you don't wana see it how i got it... :oops: was ugly!
The rims i have on there are only 6.5 inch wide... am after some 8' ones if anybody has some... have to be black though :D
