what tubes?
J_Dub
what tubes?
Post by J_Dub »
looked through forum cant find info on tubes. i want to fit tubes to my 33s, what do i fit? what size? will my local tyre shop know what to fit?
Jafa
Re: what tubes?
Post by Jafa »
Get the beasty heavy duty tractor tubes from Warren at 4wdbits.co.nz
http://www.4wdbits.co.nz/ProductDetails.aspx?productID=586
021 273 9942
jafa@inspire.net.nz
suzookyman
Re: what tubes?
Post by suzookyman »
just doin this at the mo but payin $25 per tractor tube
from the local tire shop ,if you go
with tractor tubes you will probably hav to enlarge the
valve hole
Al
Jafa
Re: what tubes?
Post by Jafa »
suzookyman wrote:just doin this at the mo but payin $25 per tractor tube
valve hole
Al
Thats a much better price! Yep you'll have to enlarge the valve hole, but its worth it for the results. Tractor tubes are much much better than car ones
021 273 9942
jafa@inspire.net.nz
Bulletproof
Re: what tubes?
Post by Bulletproof »
I have run Tractor tubes for years and as well as the fact they are heavy rubber, the other big advantage is you can take the valve out to let the tyres down in seconds. As soon as they look flat put the valve back in.
Cheer Richard
Never say die, up man and try
Re: what tubes?
just did the swap myself , 5 rims, weld up old hole, redrill for new valve stem , means strip and remount the tyres too, found my pump end didn't fit on to the new stem on the front wheels sunday got to fix that :D
gary_in_nz
Re: what tubes?
Post by gary_in_nz »
hmmm im considering going bead locks without tubes. i keep finding i am spinning up the tyre on the rim and its hurting the tubes. i let my tyres down to 10psi and lower sometimes.
Bulletproof
Re: what tubes?
I have been running tractor tubes for about ten years in both my sets of offroad tyres. The one thing I learned was the need to drill the new hole vertically next to the centre.
The first set I had I put the new hole in the same place as the original and because they are made of brass I kept breaking them off on roots and stones.
Original Position
Correct position
Welded hole
Never had any trouble with the tubes
Cheers Richard
Jafa
Re: what tubes?
Post by Jafa »
I'm doing exactly this right now, peeled one off on the weekend
021 273 9942
jafa@inspire.net.nz
J_Dub
Re: what tubes?
Post by J_Dub »
cheers heaps a good info, gota pm back someone whos offered me a set a 5 for $100
aroma
Re: what tubes?
Post by aroma »
just ordered a couple for my POS if 16" ask for mr16 tubes with ts 13 valve belive these are designed for radial tyres and the ts 13 valve fits thru exsiting hole should be paying around $25 a tube I got mine from george stocks in chch
Jafa
Re: what tubes?
Post by Jafa »
aroma wrote:just ordered a couple for my POS if 16" ask for mr16 tubes with ts 13 valve belive these are designed for radial tyres and the ts 13 valve fits thru exsiting hole should be paying around $25 a tube I got mine from george stocks in chch
Nah thats just an ordinary car valve, you want the "Heavy Duty Tyre Tube with TR218A Valve" It has a small nut that clamps the valve onto the rim, making it much stronger, and it has a large removable brass valve housing that has the valve core inside it.
021 273 9942
jafa@inspire.net.nz
Re: what tubes?
Like bulletproof says you want to redrill the valve holes for tractor tubes into the centre of the rim so there tucked away inside the rim where they cant get damaged and throw away the plastic locknuts and put some brass ones on, the problem you do find with the valve stem in the centre of the rim is the freewheeling hubs and fully floating rear hubs (if you've got them) obstruct access to the valve stems to pump the tyres up and get pressure gagues onto them, I've usually got to back off the locknut and bend the stem over to access them. The tractor tubes need a 16mm hole instead of the standard 12mm :mrgreen: :mrgreen:
Re: what tubes?
i got away with a 15mm hole
Re: what tubes?
coxsy wrote:i got away with a 15mm hole
dont tell us your insecurities
Return to “Tyres”
