rear diff for hilux
rear diff for hilux
got to pull the rear diff out of my 1990 hilux on saturday, its making a hell of a noise and grating sound when driving. does anyone know where to source one cheap? its an lsd one to. hopefully someone will have one lying around?
- hosehustler
Yep, well G285 is a 4-pinion LSD 4.3 ratio, so your best and cheapest bet will be Tims open one he mentioned above otherwise start shopping for a 4.3LSD - which will probably set you back at least $400 if you can find one outside of a wreckers... any wrecker with one will probably want well more than that.
Best bet will be to remove it and check to see whats happened - it might be a bearing which can be replaced, or it could be rust-induced early retirement - in which case it will make a nice (and VERY effective) paperweight
regards
Steve
regards
Steve
- hosehustler
