80 series front diff head wanted 4.1 ratio
Anyone who has one, please let me know. Its an NZ model plain Jane, 4.2 non turbo, 5 speed in case that makes a difference. 10 x 41, cheers, Gordon
Re: 80 series front diff head wanted 4.1 ratio
how did you kill your diff??
front diff is an 8" high pinion reverse cut gear, its a common problem for these, same with the prado diffs.....
Now the way to break a front diff in a cruiser (80 or 100) is by going backwards, so never do a reverse snatch otherwise you may loose crownwheel teeth
Putting a locker in the front won't solve anything; the locker replaces the diff CENTRE, not the crownwheel/pinion set, which is the Achillie's heel of the vehicle so that will still break.
wopass wrote:how did you kill your diff??
I'm not really sure believe it or not! Pulled up on a club run, was running well, two of us winched up a rolled 4 wheeler from 300 feet down, thought it was too slow so I asked my brake man to try driving backwards and tow it up instead, axles a little bit crossed, a bit of wheelspin in dry clay so gave it up. No sound, no nothing and i certainly didn't see anything violent enough to break anything. Then went to drive out after the recovery and "crunch crunch" unbelievable!
The unbroken bits still look good too, good tooth pattern, no obvious wear on the teeth, no partly fractured teeth from what might have been a previous effort. It looks like a perfectly good diff and its just let go. It wouldn't have been so bad if I was driving it myself and knew I'd screwed up. What a pissoff, I bought the cruiser for reliability after the Jeep, buggered if I know whether that was such a good move now....
There you are, Jerry's hit the nail right on the head, but i'm not going to retype all this.
ahh righto, yea they are strong going forward but not backwards so just something you need to be aware of and drive accordingly
I have a ring gear and pinion if you want to rebuild or are you looking for a whole diff head ?
mudzilla wrote:I have a ring gear and pinion if you want to rebuild or are you looking for a whole diff head ?
Ring gear and pinion is fine, if I can't get the easier option of a good complete head. Assembling and setting up this type of diff holds no fears for me as i've done hundreds in a past life, spare time's at a premium for me though. Is yours 10 x 41? What sort of condition? PM with price? cheers
PM sent, Cheers .. Wayne
Just counted teeth... 37/9...4.11...???????..... Out of 80 series..Hi pinion reverse cut.
mudzilla wrote:Just counted teeth... 37/9...4.11...???????..... Out of 80 series..Hi pinion reverse cut.
My life story, I always wind up with the expensive option if there's a choice. I wonder if they went to a finer tooth (41/10) in later models to enlarge the contact area to try and give it more strength - especially in reverse. i'll have to research more and if anyone can make any suggestions I'm all ears (eyes?)
I doubt the slighly slower ratio will affect much if at all on soft ground, but might make Hi 4 on the highway interesting.
Gordon
As my pm, Center diff fixes that. So close.
mudzilla wrote:As my pm, Center diff fixes that. So close.
it may be doable if the bolts line up and everything else is the same. Mine doesn't have a centre diff either. Its a part time 4WD 5 speed non turbo but it does have free wheeling hubs, its a NZ/Australian basic model.
I really appreciate everyone's help and advice, especially Mudzilla. I'm all good now, Dan Cowper has come to the rescue with a very well priced complete diff head - exactly the same as mine in fact but with a full head of teeth.
Most importantly I've learned a valuable lesson from you but I could have done with it last week. Don't tow anything in reverse! cheers and thanks again. Gordon.
Flash2004 wrote:I really appreciate everyone's help and advice, especially Mudzilla. I'm all good now, Dan Cowper has come to the rescue with a very well priced complete diff head - exactly the same as mine in fact but with a full head of teeth.
how much was it mate? just curious as i bout one off trade me a while ago for 120 bucks, back then i just bought it cos it was cheep (i think) and diddnt even have a VX
That was cheap sure enough at $120, I went to toyota today and they were ex Japan at $3000 incl gst, Dan was only $350 and I'm more then happy with that. cheers
Cool, All sorted..
- Andrew1706
This is good to know for the future, considering I've done a far few pulls in reverse (the track determined that) that went flawlessly.
I've never been keen on big angry snatches forwards let alone in reverse...
Andrew1706 wrote:This is good to know for the future, considering I've done a far few pulls in reverse (the track determined that) that went flawlessly.
Yes Andrew, its going to be interesting when the track won't allow me to turn around, if you know the weakness though, its half the battle. Anyway, Maybe a good mexcuse to get the winch rope out.
I learned the hard way with my HiLux ( 80's diffs) .. They dont like backwards loads, Specially shock loads
Your 80's is rare with part time 4x4, a cool thing a lot of 80 owners spend $$ to get.
mudzilla wrote:I learned the hard way with my HiLux ( 80's diffs) .. They dont like backwards loads, Specially shock loads![]()
it took me 5 years (and another long story) of waiting to get this one too. Has a full, padded warranted internal roll cage too. Sort of a padded cell.
Sort of a padded cell.[/quote]
I need one of those..
mudzilla wrote:Sort of a padded cell.
You can't have mine, I'm always using it. Actually, the way this truck performs (not including the broken diff) you need a cage like that just to keep Patrol drivers out.
Yes..Another total Toyota convert
mudzilla wrote:Yes..Another total Toyota convert
I've had 'em all since about 1974 Muddie, not my first Land cruiser, nor my second either, not quite a total convert...... it just goes about its business in a solid way, nothing too exciting, maybe what I need these days... I still have the weapons if excitement is called for. (Jeep, etc.)
