Garrett GT3540 with Tial 44mm wastegate
Andrew1706
Post by Andrew1706 »
Originally planned to use this on a Honda drag car but being unemployed I need to sell off cash to help with the recession blah blah blah. Thought I would chuck it up here as well.
Will be good for anybody running a 1/2JZ, 1UZ, Nissanshitbox, or any other big displacement V8 wanting more power.
Good for 35odd psi, and is rated to around 700hp
On 1.8 and 2L Honda 4CYL motors here and in the states it makes boost around 5500-6000rpm and holds it all the way to 9000 and can make up to 650whp. The VTEC motors have pretty good flowing head but a motor twice the size revving half as fast will still handle it.
http://www.trademe.co.nz/Browse/Listing ... =205274028
The wastegate plumbing was an idea given to me by a friend who did the work, should in theory provide better boost control as exhausts vent in the same direction they are flowing rather then making a 90 degree turn as per most normal manifold wastegate positions.
Andrew1706
Re: Garrett GT3540 with Tial 44mm wastegate
No takers?
interested till i read [Nissanshitbox, ] no thanks
Andrew1706
All good mate :D
Flash2004
Post by Flash2004 »
Can't help thinking this is a little bit like that other thread where the guy welded up his pinion to his crownwheel to "lock" his diff. i wonder why no one's bid on it? Only $2500 too!
Andrew1706
Retail is a hell of a lot, you can get '3540's on trademe for like $500 or so but they are chinese, this is genuine hence the price.
Was going to put it on my 80 Series Cruiser but decided all the effort in modifying the engine, pump etc would just mean I would wait longer to wait for the Nissans to catch up :wink:
