break bleadin prob
break bleadin prob
after bleeding brakes with motor off they are fine and hold pressure but when turn it on they lose it all and the pedal goes to floor. what is wrong
Re: break bleadin prob
benorange wrote:after bleeding brakes with motor off they are fine and hold pressure but when turn it on they lose it all and the pedal goes to floor. what is wrong
booster is buggered probably, your idle is probably high as well, pull the vacume hose off when its running and plug the pipe and see what happens
