pto winch with a auto
Posted: Mon Mar 09, 2009 3:32 pm
by allmud
as u might allready know i now have fj40s cruiser its got a 350chevy and turbo 400 auto ive been offered a pto off a cruiser with all the bits the question is can i run a pto and auto at the same time ? if so how dose it work eg put in in drive while winching ot netural etc
any help would be good thanks
Re: pto winch with a auto
Posted: Mon Mar 09, 2009 3:47 pm
by Mud Hog
Posted: Mon Mar 09, 2009 4:51 pm
by sig
cant really see why it cant be done as the pto drives off the transfer .only issue may be when you put transfer in neutral for winch operation auto may start spooling up and turning winch on its own accord.ummm that could be a problem.unless you had some form of trans brake .maybe some one else has some other ideas :?:
Posted: Mon Mar 09, 2009 5:04 pm
by SV1K
The PTO shouldn't drive until you engage the gears, so when you are in neutral (transfer box) you will then have to engage the PTO leaver to winch, wouldn't recommend driving and winching with an auto though might end up very messy if/when it goes wrong.
8)
Posted: Mon Mar 09, 2009 5:07 pm
by PigFmr
my mate has a 70 series cruiser auto with a factory pto goes well and u can drive and winch at the same time
vince...
Posted: Mon Mar 09, 2009 5:16 pm
by muddyplumber
had an auto cruiser with pto, if you engage pto then put it in drive it works sweetas, had no problems.
Posted: Mon Mar 09, 2009 5:53 pm
by zookfest
you can always put the high/low lever in neutral then select the pto lever and ingage it then put in drive,this will run only the winch.Once high /low is in low that will drive the truck at the same time,id snap it up they are great winches :wink:
Posted: Tue Mar 10, 2009 10:35 am
by allmud
sweet as thanks to all u smart people out there
Posted: Tue Mar 10, 2009 3:46 pm
by mudlva
just be careful with the turbo 400 trans as going from drive into netrual then reverse the trans itself doesnt like this as the trans when taken out of drive and into netral is still turning in the drive direction. ive had to go to a hydrolik system to get away from the issue of either graunching reverse or having to turn off the motor to engage reverse.
the toyota autos have a brake system that stop the trans from turning whne it is put into netrual.
to explain further with the transfur box in netrual the wheels are disconected from the transmission output sprocket/gear thingy. you engage pto to start the winching process. reverse is to winch out, drive to winch in. going between the in and out process is where the problems arise.
