Wheel issue
- southland_Feroza
- Driver/Navigator
Wheel issue
Hi On my 1990 feroza one of my wheels have been making a ANNOYING rumbling noise as i drive. It starts at about 50kph. I jacked the front right wheel up and noticed it had a bit of play in it (it wobled a bit). Any ideas what this could be or if its even the cause of my annoying noise????
Re: Wheel issue
Sounds like a stuffed wheel bearing to me
Re: Wheel issue
what tallsam said
Wheel bearing do tend to make a rumbling type noise (sometimes but not always, with a slight vibration coming through the steering)
HOWEVER!!! My 94 Feroza had a "rattle/clatter" in the Right hand front wheel from day one ... came in at slow speeds (5-15 kph) never did find out what it was, came to the conclusion it was missing some anti rattle springs in the front brakes as the front wheel bearings where fine.
- southland_Feroza
- Driver/Navigator
Re: Wheel issue
Are front wheel bearings tough to change?
Re: Wheel issue
no , just make sure you parm grease into new bearing before you install them replace rear seal on ya hub , follow workshop manual in touqueing new hub nuts up
